when is building the upper end necessary
Old Sep 10, 2007 | 10:14 AM
andyisphat2004's Avatar
andyisphat2004
Default when is building the upper end necessary
I searched but i couldnt find a definitive answer. At what point is building the upper end necessary?
Old Sep 10, 2007 | 10:19 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
are you talking about the heads?
Old Sep 10, 2007 | 10:22 AM
Old School's Avatar
Old School
Shift_Boost
when you want to make 600whp or more.
Old Sep 10, 2007 | 10:46 AM
andyisphat2004
heads/cams
Old Sep 10, 2007 | 11:00 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
if you have the money then when your building the bottem end you might as well get cams and **** while its open.... it will save you money and you can make more power on less boost
Old Sep 10, 2007 | 11:16 AM
Zivman's Avatar
Zivman
Originally Posted by andyisphat2004
heads/cams
I would say cams if you plan to go over 500. then headwork if you want upper 500's -> 600+
Old Sep 10, 2007 | 11:20 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Since nobody agrees on what exactly 500 or 600whp is...this is a tough question to answer. What dyno?
500whp on our dyno....no problem with stock heads...which would be about 550whp on a dyno jet. After that, cams and head work work really help the engine sing much better.
Old Sep 10, 2007 | 11:46 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Because there isn't one
We made 780whp on stock heads/cams with no problems, but the motor would definitely have benefited from cams and headwork. Even a stock motor would benefit from heads+cams, but I would recommend it once getting into the 500...600+ range as you will see some nice results. If you are building the motor, that is definitely the best time to do your headwork imo becase tearing the heads off later isn't so fun.... exhaust manifolds have to come off, front end must be torn down to remove the timing covers, chains, etc.
We have some nice head packages if you are looking to go down that road. PM me or give us a call if interested.
Old Sep 10, 2007 | 12:42 PM
Matt at PF's Avatar
Matt at PF
if you want you can add some upgraded cams and springs to the top end.
Old Sep 10, 2007 | 01:36 PM
QuadCam's Avatar
QuadCam
I have some heads being worked on ( by a former Pro Stock Bike Champion!!!) at the moment. Once they are, I'll be having custom cams ground to maximize these heads.
Old Sep 10, 2007 | 01:44 PM
rcdash's Avatar
rcdash
I think the golden question is "what is the return on investment"? The slope of the $/hp curve becomes much steeper past a given point...
Old Sep 10, 2007 | 01:50 PM
taurran's Avatar
taurran
Cams are a huge plus when building a motor for power. I haven't seen any definitive reason to upgrade the valvetrain or port/polish the heads unless you're going for 800+whp. But, it definitely won't hurt...
Old Sep 10, 2007 | 04:42 PM
TTRANK's Avatar
TTRANK
From everything I have found cams/springs are a good idea at any time but anything past that is not needed unless you are going for BIG power ~600+
Old Sep 10, 2007 | 05:24 PM
QuadCam's Avatar
QuadCam
my goals are for making the most power I can only on pump gas. therefore, I'll need a very efficient head, port, cam package that'll allow me to make more power at lower boost levels. Hopefully, it works!
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
pr_350z
Oct 1, 2015 05:03 PM
