5AT Upgrades for boost.
Old Sep 12, 2007 | 08:08 AM
goosegoose's Avatar
goosegoose
Originally Posted by Chucky
It was an Edge Racing TC. The car is putting down 385rwhp.
The tranny was running a little hot so I installed a B&M tranny cooler. Then it was running a lot better. Put the 3500 TC on and progressively it got worse. Within a month it was dead.
This is all very good information.
Did adding the Edge Racing TC drastically improve power performance?
Old Sep 12, 2007 | 08:16 AM
Chucky's Avatar
Chucky
Drastically? No. If there was a gain it wasn't much and it didn't last too long.
Now the valve body... that rocks! Very solid and quick shifts.
Old Sep 12, 2007 | 08:17 AM
goosegoose's Avatar
goosegoose
I know what you mean. After FI, my OEM valve body was COMPLETELY insufficient. After that, I went with a Level Ten valve body, but it is not completely up to par either.
What brand of a valve body did you go with?
Old Sep 12, 2007 | 08:18 AM
Chucky's Avatar
Chucky
Originally Posted by istan
Yeah, but what's the size of the cooler? Those circles are just the inlet/outlet to the cooler inside the radiator.
Coach, are you running an aftermarket radiator? Or is your tranny cooler an additional auxilary cooler?
The cooler is just a small strip along the bottom of the radiator. It really is insignificant.
Old Sep 12, 2007 | 08:19 AM
Chucky's Avatar
Chucky
SGP...
Old Sep 12, 2007 | 08:24 AM
goosegoose's Avatar
goosegoose
SGP...
Awesome. The SGP unit is exactly what I had in mind next.
I asked Thomas at SGP a simple pre-sales question. If I floored the car in full auto mode, would the SGP VB ever miss a shift? He said no. Can you vouch for that?
Also, how hard are the upshifts and downshifts when you are cruising at low throttle?
Thanks again!
Old Sep 12, 2007 | 08:30 AM
Chucky's Avatar
Chucky
Thanks again!
Have never missed a shift. When you floor it at speed, it downshifts HARD... actually a double downshift. From a dead stop, it takes off really smoothly and will chirp the tires shifting into second and third. Very stout.
Under normal driving the shifts are strong but not teeth chipping hard. It does take a little bit of getting used to. Trust me though, it is all worth it.
Old Sep 12, 2007 | 08:31 AM
iStan's Avatar
iStan
ZR
Sweet. I feel better knowing that.
Old Sep 12, 2007 | 08:34 AM
goosegoose's Avatar
goosegoose
I think you sold me.
I hope there is not a long wait or too long of a downtime for this part from SGP.
Old Sep 12, 2007 | 08:47 AM
helldorado's Avatar
helldorado
Its not as much a cooler as its a heat exchanger. One of its main purposes is during warmup, to grab heat from the hot coolant running through the radiator to help warmup the transmission fluid before the car is put into motion. Its cooling effects are definitely limited.
Old Sep 12, 2007 | 08:48 AM
coachk's Avatar
coachk
No aftermarket radiator for me. I have the hoses go right from the aftermarket tranny cooler to the tranny.The tranny cooler I have does a better job than the small OEM cooler.
Old Sep 12, 2007 | 08:49 AM
coachk's Avatar
coachk
^^^ +1
Old Sep 12, 2007 | 08:55 AM
wild121's Avatar
wild121
I will Vouch for chuckys car. Very smooth and yes he does chirp the tires in going into second and third.
Old Sep 12, 2007 | 04:49 PM
Thomas @ SGP's Avatar
Thomas @ SGP
Default Told ya!
There are a quite a few out there and there will be more soon. Glad you are enjoying it Chucky.
Old Sep 12, 2007 | 07:23 PM
minus500's Avatar
minus500
Originally Posted by Cube
Did you just randomly throw numbers around that you've heard before? 325 rwhp is close to the factory rating number (NUMBER) of 330 ft-lbs torque at the crank, where it's been factory rated at 100,000 shifts @ 330 ft-lbs torque. I've never seen that number (325 rwhp) being referenced as a safe "stopping point" of the stock transmission. I've also never heard solid answers to what the VB and TC will support, but I highly doubt it'll raise from "shouldn't go past 325 rwhp" all the way to "500 rwhp."
In all reality, who has destroyed their 5AT, built or not, from too much torque?
Correct me if I'm wrong, but isn't torque the killer of the tranny?
I know of a 507 rwhp tc+vb upgraded 5AT... what other numbers have you heard of on the 5AT? The 507 is runnin fine so far (VRT JWT TT )
LOL! I have a fully built SFR trans but, I probably don't know much about the 5AT. I was just saying what would keep the trans in optimal shape for an extended period of time. You could probably make 500whp on the stock tranny but how long will it last. And yes, torque is the killer. I remember a known tuner posting on these boards say that a VB and TC will go to 500whp but, not much further. Thanks for putting me in my place and making this thread so much better.
Old Sep 12, 2007 | 07:57 PM
rcdash's Avatar
rcdash
Is the SFR tranny giving you trouble at high hp/tq levels? Is that the basis for the recommendation for a GM tranny upgrade beyond 500? I thought that thing was designed for 800-1000 hp...
Old Sep 12, 2007 | 10:42 PM
acg's Avatar
acg
I have an upgraded TC from Edge Racing and also an upgraded VB from GTM, they did the install on both along with a oil cooler and tranny cooler.
When I left the car was putting down 410rwhp and I had no issues, right now the car is back with them with a new engine ( lower compression) and a few other things, we shall see what the setup can handle now.
Before the APS TT, I had a Voretch with 400rwhp and I was running on the stock setup for over a year with no issues. Soon as I went to the TT I started to have shifting issues which maybe due to the more trq I had acquired.
Old Sep 13, 2007 | 08:55 AM
  #38
Jtrain's Avatar
Jtrain
So from what I gather, If I go over 500whp I need the full tranny and not just the VB upgrade?
Old Sep 13, 2007 | 09:29 AM
  #39
coachk's Avatar
coachk
500 tops..Probably a good idea when you hit 450 and more importantly watch your TQ numbers.
OT..you going to the Bradenton event on 9/30? My car will be a good example of what this tranny can handle.
Old Sep 13, 2007 | 09:47 AM
  #40
marques1's Avatar
marques1
I don't know if anyone has told you this yet but its not really horsepower that kills that auto tranny it is the torque. It is dangerous to go over 400rwtq in the auto tranny. This is also a very interesting thread but i have one question someone mentioned a auto that has 517rwhp im figuring this is TT if so those torque numbers should be over 400 so how is it making this type of power without slipping with just a vb and tranny cooler.
