5AT Upgrades for boost.
Old Sep 13, 2007 | 10:12 AM
  #41
Chucky's Avatar
Chucky
Originally Posted by marques1
I don't know if anyone has told you this yet but its not really horsepower that kills that auto tranny it is the torque. It is dangerous to go over 400rwtq in the auto tranny.
That's kind of what I said when I said my upgraded TC killed my tranny.
Old Sep 13, 2007 | 10:22 AM
  #42
marques1's Avatar
marques1
chucky you got me before i got to edit read the rest bro, thanks! Your to fast with your responses slow your roll just kidding.
Old Sep 13, 2007 | 10:49 AM
  #43
Jtrain's Avatar
Jtrain
Man I really don't want to spend 4500 on a new tranny, thats so much money lol =\ Guess you gotta pay to play
Old Sep 13, 2007 | 11:07 AM
  #44
marques1's Avatar
marques1
j train the question you should be asking is how much torque can my car hold. Im not sure if anyone has a definite answer but the best person you should ask is i think his screen name is fcon he has i believe a 500+ hp z with lots of torque.
Old Sep 13, 2007 | 12:42 PM
  #45
Chucky's Avatar
Chucky
It's all good...
  #46
Chucky's Avatar
Chucky
You won't regret it I'm sure.
Old Sep 13, 2007 | 01:25 PM
  #47
roncfpz's Avatar
roncfpz
Heat is the primary killer of the 5AT. You must keep your AT fluid temps in a range of about 175 to 200, otherwise it begins to break down and so do parts thereafter.
Old Sep 13, 2007 | 01:26 PM
  #48
coachk's Avatar
coachk
I'm at 410 TQ and so far so good...I agree that it is TQ that killls your tranny, thats why I posted to watch your TQ numbers.
Ron...if I'm not mistaken its the TQ that causes heat issues.Do you have a tranny temp gauge?
Old Sep 13, 2007 | 02:48 PM
  #49
Jtrain's Avatar
Jtrain
m arques don't trip up over words, you know exactly what i'm asking and 40 people have already corrected me
Old Sep 13, 2007 | 04:56 PM
  #50
Scythenc's Avatar
Scythenc
so from what i gather reading the thread. the consesus is
400 ftlbs tq = max recommend power on stock trans
500 ftlbs tq = max recommend power on trans with valve body upgrade, torque converter and tranny cooler
500 ftlbs tq+ = built race trans
now ive seen where people have mentioned doing a swap to the th350 and th400 trans by gm. but has anybody ever put a sequential racing trans into a z before? if i ever got to the point where i would have to swap my 5at i think its something i would like to attempt.
Old Sep 13, 2007 | 07:24 PM
  #51
helldorado's Avatar
helldorado
High torque causes slippage in the clutch packs and that's what generates heat.
Also, depending on the design of the torque converter, more aggressive stall speeds generate heat with higher pumping losses, which also reduces efficiency.
Old Sep 14, 2007 | 06:15 AM
  #52
roncfpz's Avatar
roncfpz
Agreed, the add'l torque certainly generates more heat which ultimately leads to failure of parts. In particular, the stock clutches cannot handle sustained abuse from the add'l torque which quickly raises fluid temps.
I believe the type of abuse will mainly determine the "acceptable" levels of HP and torque. Short 1/4 miles bursts may not raise temps enough for sustained damage and the tranny may last longer at higher levels of HP and TQ. More prolonged abuse such as from road course tracking etc. will tax the trans fluid much more.
After my motor was built, I was at 459whp on Sharif's dyno with about 450TQ. With only VB upgrade the trans would have some issues with TQ but ran well in short bursts from 0-100mph. Once I ran the twisties with a local exotic car group I boiled the fluid twice and put the trans in protective mode. Thereafter I upgraded the trans cooler and ran it hard at ZDayZ and did not have any issues. That trans today is running great in another car.
Old Sep 14, 2007 | 06:19 AM
  #53
roncfpz's Avatar
roncfpz
I do not but I'm looking into getting one later. I would like to integrate the temp sensor with the FCon to datalog temps.
Old Sep 14, 2007 | 08:44 AM
  #54
Chucky's Avatar
Chucky
Yeah mine!
Old Sep 14, 2007 | 08:51 AM
  #55
Cube's Avatar
Cube
Originally Posted by minus500
Thanks for putting me in my place and making this thread so much better.
Ummm no problem. You're the reason I replied in the first place, I'd rather not see some BS numbers thrown around on a whim
As far as the different valve bodies, I've heard a little more on why L10 isn't recommended. If you search around on VB's, you'll see responses to posts about looking into getting the L10 upgrades saying things like "Don't! They're crap!" with little further elaboration.
Someone posted pics of it up here, and was told the clutch packs pictured were no better than the original clutch packs in the tranny. Another guy who had a L10 kit said he didn't see anything extra in terms of clutches when they had to tear it down and rebuilt it That same person also said the L10 TC felt like a turd in daily driving (would lunge forward in weird moments in the lower rpm band) and he couldn't stand it and went with Edge Racing and was much more satisfied. Just FYI if/when any of you decide to upgrade, although it looks like general consensus here is good experience / feedback with the SGP products (which I'll probably go with soon).
Old Sep 14, 2007 | 10:58 AM
  #56
minus500's Avatar
minus500
I agree.
Old Sep 14, 2007 | 11:03 AM
  #57
minus500's Avatar
minus500
You got me again. I never researched anything before I got my built trans, I just did it on a whim. Give me a break, I already said I don't know anything about F/I or 5At's. Lets not turn this thread into a flame fest. Where in VA are you and what are your mods?
Old Sep 14, 2007 | 11:04 AM
  #58
wild121's Avatar
wild121
Just dont cheap out like you did on the rest of the car. You need to get a good gauge.
Old Sep 14, 2007 | 12:54 PM
  #59
rcdash's Avatar
rcdash
^ WTH, cheap out? Ron has one of the classiest cars i've ever seen - maybe that's an inside joke or something?
I was hoping for a long time that Osiris would be able to read the TCM temp sensors but that's still a no-go. So when I finally ended up building the car, I opted to install a trans temp sensor and hooking it up to an Innovate logging system.
Old Sep 14, 2007 | 01:22 PM
  #60
helldorado's Avatar
helldorado
Might've been Rookie and me. He showed me a pic of the kit that L10 sent him and I saw a lot of parts in there that were from a TransTec overhaul kit. Was very disappointing. I know brnjug has had good results, but his build was done in-hourse vs a mail order kit.
