Dyno Graph
Old Sep 19, 2007 | 12:44 PM
kevin8086's Avatar
kevin8086
Default Dyno Graph
ok here is a pic of my dyno tuning i just had done, Greddy TT, 650cc inj. a little lower than i would like to have at 8psi but it's still fun to drive. this is a stock motor with single
3" custom exhaust tuned with a u-tec on 91. so what do you guys think?? i was hoping more for 400/400. A/F ratio is solid though
Old Sep 19, 2007 | 01:09 PM
westpak's Avatar
westpak
SFZCC
you wont get there at those psi levels with a single exhaust
what about test pipes?
Old Sep 19, 2007 | 01:58 PM
kevin8086's Avatar
kevin8086
i have straight through exhaust, test pipes and all. on 93 octane it was making 414 whp and 400 tq on 8 psi.
Old Sep 19, 2007 | 02:55 PM
DMK's Avatar
DMK
What's your A/F at redline? 11.5?
Old Sep 19, 2007 | 02:58 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Bro! Thats great power at the psi level and 91 pump gas, with 93 and true duals 400 is no problem.
Dont be down...Thats good power.
Old Sep 19, 2007 | 03:11 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Very good numbers. The single exhaust is the culprit.
Old Sep 19, 2007 | 03:25 PM
kevin8086's Avatar
kevin8086
it's a nice smooth delivery. maybe i need to save for an exhaust for that little extra powa
Old Sep 19, 2007 | 03:26 PM
kevin8086's Avatar
kevin8086
not too sure but it wherever it's at its even the entire way
Old Sep 19, 2007 | 10:59 PM
kevin8086's Avatar
kevin8086
sooo if that isnt so bad then why (this is just a ?) does someone locally have an aps tt kit with 416whp on 91?? and i'm only and 385?? my 94 rx7 with a single tuebo on the 1.3 litre had 390hp.
Old Sep 19, 2007 | 11:19 PM
iStan's Avatar
iStan
ZR
Different setups? Different Exhausts? Tuned for heat? Who knows?
Old Sep 20, 2007 | 05:19 AM
IIQuickSilverII's Avatar
IIQuickSilverII
+1 on that its great power still...but...i have seen 400s at that psi here in az at 91 on Dj uncorrected...all running strong.....all with safe a:f
actually the 3" single is enough for well over 400s
Old Sep 20, 2007 | 05:46 AM
rcdash's Avatar
rcdash
very smooth curve - nice!
Old Sep 20, 2007 | 05:48 AM
westpak's Avatar
westpak
SFZCC
Tough at 8 psi on a TT kit
Stop whining and enjoy the car, with a single exhaust system the turbos get bottled up as the rpm's go higher, your torque is fine as it is down low but your hp suffers as it is up high in the rpm range, you switch to a dual exhaust and the top end will free up and get that extra hp up top.
Old Sep 20, 2007 | 06:41 AM
TENGAI's Avatar
TENGAI
Looking good. For 8psi on 91 with a single exhaust - great power. Should be nice and "safe" for the stock block.
Old Sep 20, 2007 | 07:03 AM
iStan's Avatar
iStan
ZR
Kevin, You're tuning the same setup on a lower octane and making it safe. You know you weren't going to hit the same levels or expect it to barely change by doing that.
Old Sep 20, 2007 | 07:58 AM
kevin8086's Avatar
kevin8086
no, i know i was going to loose power but now in the top end 4-6th it just feels like it's holding back, almost like i only get 90% throttle instead of 100% throttle. it still feels good just not screaming like it use to on the top. i dont mean to sound like i'm complaining i really enjoy the car and your responses definately make me feel better
Old Sep 20, 2007 | 11:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Those #'s were close to my TN kit and that at the time felt FAST to me, just enjoy your car man. IMO-not worth the money and hassle to swap exhausts, freshen up the tune, etc for 20 or so whp...
Old Sep 20, 2007 | 03:37 PM
kevin8086's Avatar
kevin8086
oh, that is a fresh tune.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
