Removing MAF sensor?
Old Sep 27, 2007 | 07:06 AM
moog's Avatar
moog
Default Removing MAF sensor?
How many UTEC users have removed their MAF sensor? Not sure if I'm understanding correctly. Documentation says that if you have the MAP sensor for speed density fueling, you can remove the MAF for more air flow.
Old Sep 27, 2007 | 07:27 AM
rcdash's Avatar
rcdash
Then you've got to have the UTEC controlling everything... Also with no MAF, you're gonna throw a CEL - no idea how'd you'd fix that without a reflash at least. I doubt many run with no MAF at all in place.
Old Sep 27, 2007 | 07:32 AM
Q45tech's Avatar
Q45tech
Haven't measure a G35 MAF however Nissan usually limits MAF flow restriction to < 7" water column so pulling the element might only gain 4-5" /27.7 = 0.144 x 6.8 or <1% less restriction.
Old Sep 27, 2007 | 07:53 AM
G35asian's Avatar
G35asian
Check out my response on G35Driver
Old Sep 27, 2007 | 08:31 AM
westpak's Avatar
westpak
SFZCC
A few issues, the Utec still uses the ECU to control the 0% column or idle/cruise areas, so that alone would prevent you from doing it the car would not run.
Second as mentioned you would get a CEL and thirdly you would lose intake temp reading.
Old Sep 27, 2007 | 10:01 AM
QuadCam's Avatar
QuadCam
Westpak,
you can set your open loop fuel parameters to start at -10 psi and go up to whatever psi you need. In theory, you'd have the UTEC in control of fuel and timing all the time with those settings. I've never tried it, and I'm not planning on it either, but I believe that is what the OP wanted to know.
Old Sep 27, 2007 | 10:05 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i actually set up my all motor setup like that , -12 psi to 0 and it fully controlled everything..
a lot more consistent for sure
Old Sep 27, 2007 | 10:07 AM
failsafe306's Avatar
failsafe306
So it basically acts as a standalone then, right?
Old Sep 27, 2007 | 11:02 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Correct. When we remove the MAF on Haltech cars an air temp sensor must be wired back in and calibrated.
westpak's Avatar
westpak
SFZCC
Originally Posted by QuadCam
Westpak,
you can but it depends on what range of psi he is talking about 11 columns is just tight for a wide range and virtually not an option when boosting even low boost for a smooth operating car
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
