CJm Stage 2 - Slow Leak
Old Oct 15, 2007 | 12:45 AM
jining's Avatar
jining
Default CJm Stage 2 - Slow Leak
Well, recently when I had my car up on the rack, my shop noticed that the fitting that joins the hardline to the fuel output hose had a droplet of fuel on it, they retightened it but it still seems to have a VERY slow leak. Anyone else have this problem? Is it a major concern? Could the reason there is a leak be because I am @ ~58PSI fuel pressure? I know that is higher then normal.
Thanks,
Aaron
Old Oct 15, 2007 | 02:53 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Thanks,
Aaron
Try using some teflon tape or teflon paste on the threads,that should seal it up.
Old Oct 15, 2007 | 03:04 PM
jining's Avatar
jining
I thought teflon was not fuel resistant
Old Oct 15, 2007 | 04:20 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I used teflon tape on mine and it sealed up great.
Old Oct 15, 2007 | 05:30 PM
failsafe306's Avatar
failsafe306
I wouldn't use tape, it can shred and get in your fuel system, and you surely don't want that. Plus it will probably break down over time and start leaking again. If it's an AN line, you shouldn't need anything at all, just tighten it more. If it's NPT, use a liquid thread sealer rated for oil/fuel use.
Old Oct 15, 2007 | 05:32 PM
jining's Avatar
jining
Hmm not sure if it is AN or NPT, maybe phunk can chime in
Old Oct 15, 2007 | 05:36 PM
failsafe306
I'm assuming it's probably an AN line. Can you not tighten it another 1/4 turn or so?
Old Oct 15, 2007 | 11:48 PM
jining's Avatar
jining
apparently my shop tightened it up a bit, I dont want to over tighten it
Old Oct 16, 2007 | 09:39 AM
oorx7's Avatar
oorx7
Vendor - Former Vendor
Sounds like it is the hard line adapter. The piece that actually crimps onto the stock hard line. This has to be very tight. Make sure that you don't tighten the AN fitting while you are tightening the hard line adapter. And don't use Teflon tape for the reasons mentioned above.
I am sure Phunk will chime in as well. If not I will let him know later today when I talk to him.
Old Oct 16, 2007 | 11:58 AM
jining's Avatar
jining
Thanks, oh by the way I am not using the stock hard line. I will attempt to tighten it more.
Obadabot
Jun 18, 2023 11:31 PM
Twenty4
Jan 17, 2016 01:20 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
