My build up project pics
Old Oct 18, 2007 | 06:48 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default My build up project pics
I've been gathering up parts for the past 7 months and it's finally under way!!
Here is my spec:
Engine:
* GTM stage 0 short block
*06' Rev-up oil pump upgrade
Turbo:
* APS twin turbo kit
* Forge actuators
head:
* GTM turbo stage 2 cams
* JWT high cam springs and shims
fuel:
* CJM stage 1 fuel return system
* Walbro 255l fuel pump
* SARD 1000cc low impedance fuel injectors
Drivetrain:
* Carbonetics/ATS twin carbon clutch with 1350 pressure plate
* Cusco RS 1 or 2way adjustable LSD
exhaust:
* APS 3.5" test pipes
* Greddy EVO TT 3" true dual exhaust system
Cooling:
* PWR 40mm dual core radiator
* Samco silicon hoses
* Pathfinder SUV cooling mods
EMS:
* F con V Pro version 3.21 or better
Gaskets & tie downs:
* Nissan engine rebuild gasket kit
* HKS head gaskets
* ARP L19 head studs
Exterior:
*Shines auto project Amuse front bumper + front CSL diffuser + sides
* Chargespeed rear bumper + rear carbon diffuser
GTM short block with L19 head studs
GTM stage 2 cams
F con v pro + harness
Carbonetics twin carbon clutch
Chargespeed rear bumper+carbon diffuser
Old Oct 18, 2007 | 07:40 PM
taurran's Avatar
taurran
Niiice. Sounds like you're doing it all at once with the right parts. What are the power goals?
Oh, and which wastegate springs did you go with?
Old Oct 18, 2007 | 07:54 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Thank~ Somewhere inbetween 550~600whp.
I'm using the red spring~ I had a thread about this and all the pro tuners on this forum recommends the red spring for my power goal.
Old Oct 18, 2007 | 07:58 PM
jksstar's Avatar
jksstar
looks like a nice setup, 550+ should be easy to come by
btw I really like that rear bumper
taurran's Avatar
taurran
Yep, that would definitely do it for ya. I know that they used to say yellow springs until recently the debate was squashed!
Good luck with the build. Should be fairly simple to reach your goals.
Old Oct 18, 2007 | 08:01 PM
Zilvia's Avatar
Zilvia
this looks to be a very sick build......
def looks like good set up to get sideways.
Old Oct 18, 2007 | 08:18 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Thanks guys~ I'll update this thread with new pics often..
My heads are off to a machining shop for resurfacing..
I'm debating wheather I should paint the timing cover black, polish or chrome it... Any thoughts?? Chroming it might not be such a good idea because chome will cover the gasket surfaces and bolt holes... I don't know..
I'm definitely painting the valve covers red.. I was sold after seeing Z1 motorsports's NA engine...
Old Oct 18, 2007 | 08:19 PM
Zilvia's Avatar
Zilvia
do black......chrome engine stuff is ricey
Old Oct 18, 2007 | 08:44 PM
Zivman's Avatar
Zivman
Build looks good.
Can't wait to see the final tune/charts
Old Oct 18, 2007 | 08:56 PM
oro's Avatar
oro
I'm debating wheather I should paint the timing cover black, polish or chrome it... Any thoughts?? Chroming it might be very difficult trying to avoid chroming all the gasket surfaces... I don't know..
Keep it a light color, just in case you develop leaks or what not, it's a lot easier to spot than dark colors.
Old Oct 18, 2007 | 08:57 PM
tig488's Avatar
tig488
looks like its gonna be a nice build, good luck.
Old Oct 19, 2007 | 02:39 AM
Philthy's Avatar
Philthy
Boost Junkie
Looks like you're having fun and about to have a fast car on your hands... I was just in Seoul twice in the last three weeks and plan on being out there again in mid Nov - I'll shoot you out a PM before I head out next time...
Old Oct 19, 2007 | 06:41 AM
NA&CH's Avatar
NA&CH
Nice parts list. Good luck with the build.
Chris
Old Oct 19, 2007 | 07:56 AM
BrianLG35C's Avatar
BrianLG35C
Well thought out and planned build. Looking forward to seeing your numbers. You'll love the EVO TT.
Old Oct 19, 2007 | 09:40 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Please do~ And thanks everyone~~~ I couldn't have put together the parts list, nor get the parts I needed without many of your direct and indirect help!! You know who you are~
Old Oct 23, 2007 | 06:51 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default More pics!
Head work...
Valve work...
My DIY project..
Engine assembly begins
Pathfinder cooling mod
Getting there~
Old Oct 23, 2007 | 07:05 PM
DMK's Avatar
DMK
Nice. Which shop in Korea is this?
Old Oct 23, 2007 | 07:44 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
It's a racing team called Griffin racing team.
They mainly build race cars.
Old Oct 23, 2007 | 10:34 PM
Zridder19's Avatar
Zridder19
Nice setup
Old Oct 23, 2007 | 10:38 PM
zpeedDemon's Avatar
zpeedDemon
nice subscribing.
