Best manifold spacer for FI?
Old Nov 1, 2007 | 06:15 AM
  #41
chris'smax's Avatar
chris'smax
taurran, how do you like your solid motor mounts? Did you get used to yours?
I have them on my car and i am not a fan of them so far . They are not bad when in motion, but they suck when the car is stopped.
Old Nov 1, 2007 | 06:28 AM
  #42
taurran's Avatar
taurran
I've only actually driven my car with them during the week I broke in the car and personally it didn't feel too bad. From what I remember the car had a little more vibration but it didn't bother me too much.
We were talking about it the other day. On a tight fitting setup you're going to get vibration whatever way you go. If you don't have solid mounts theres the possibility it MAY vibrate from engine movement, but if you put the mounts in you'll definitely have some slightly less annoying vibration.
Old Nov 1, 2007 | 07:11 AM
  #43
chris'smax's Avatar
chris'smax
i also had to put mine in due to possible clearance issues with the TT kit.
Old Nov 1, 2007 | 11:01 AM
  #44
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
motordyne, def.
Old Nov 1, 2007 | 11:23 AM
  #45
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I've been thinking of doing this for quite some time ... getting the solid mounts basically accomplishes something similar to the engine dampeners too right?
And what about "softer" solid engine mounts like polyurethane?
Old Nov 1, 2007 | 12:43 PM
  #46
taurran's Avatar
taurran
Yeah, it's pretty much the same thing but instead of damping the torque over of the motor, it just transfers it directly to the frame, steering wheel, your hands, butt, etc.
I believe in theory it should *slightly* improve handling (lowers the center of gravity of the motor), throttle response, and might make a very slight amount of power (no rotation of the motor to absorb torque). That's just my own thoughts though... I haven't driven the car enough with them to be able to say if mine made a noticable difference.
I guess a urethane mount could work. The vibration seriously isn't that bad unless you can only drive a car that feels bone stock.
When I was breaking in my car I had a messed up timing chain tensioner and found that much more annoying than any sort of vibration from the solid mounts. (this was fixed soon after, btw)
My suggestion would be to ride in a Z with solid mounts to decide if you can take it first.
Old Nov 1, 2007 | 01:40 PM
  #47
chris'smax's Avatar
chris'smax
thats a good point, i mean when i dropped my car off i only had exhaust mods done to it and the car litterally only had 9XXX miles on it. I picked it up and it had a TT kit, coilovers, 6 puck clutch, clutch line, and coilovers. Needless to say i need to get used to driving the car.
They aren't bad when you are doing aggressive driving, but when you are realxing and just driving around town they get annoying
