Stock oil pump=FAIL
Old Nov 3, 2007 | 09:25 PM
  #41
QuadCam's Avatar
QuadCam
Originally Posted by miamimax96
But the VQ crank is shorter, forged, has 4 bolt mains and a girdle. Again, I invite people to direct me to cases of VQ crankshafts snapping due to excessive torsional vibrations.
Is it forged? It looks like it is cast to me. I am not an expert, but the non-machined surfaces look to be cast on the VQ crank.
also, the number of main cap bolts doesn't affect crank flex occuring at the rod journals of the crank.
Old Feb 21, 2008 | 12:35 PM
  #42
Julian@MRC's Avatar
Julian@MRC
Update....The Crank from this motor was CRACKED!! We had it Magnafluxed..Had Hairline cracks near the Thrust and mains..
Old Feb 21, 2008 | 12:56 PM
  #43
thawk408's Avatar
thawk408
Sounds like to me something else was up, besides a high rpm 2-step.
Old Feb 21, 2008 | 04:13 PM
  #44
Russ@Z1's Avatar
Russ@Z1
eeek
Old Feb 21, 2008 | 04:49 PM
  #45
h2kSPiG's Avatar
h2kSPiG
Just to let you know, the VQ30 oil pump likes to crack if it goes over 7300-7500. Very similar problem. There are several people trying to rev the shorter stroke VQ30 to 8000 or over and almost all of them had the oil pump blow eventually while the rods hold up fine.
http://forums.maxima.org/showthread....light=pump+oil
Old Feb 21, 2008 | 05:10 PM
  #46
06Track's Avatar
06Track
It will be hard to tell what cracked the Crankshaft, but there again I still
think a Harmonic Balancer sure would not of hurt the situation...maybe
would have helped prevent it. If the oil pump broke because of
excessive harmonics, just think of all the other components it affects.
We have to remember, we are pushing these engines to 3 times more
than the factory Dampner was designed for...some don't even run those.
