Opinion on vortech
Old Oct 31, 2007 | 12:26 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Default Opinion on vortech
Looking to achieve 13/14 psi what pulley size and belt/belt size do you suggest. I have the rev-up kit. Thank you
Old Oct 31, 2007 | 12:44 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
well??!?
Old Oct 31, 2007 | 12:47 PM
cdoxp800's Avatar
cdoxp800
vortech FAQ: read this before asking vortech questions
https://my350z.com/forum/forced-induction/270770-vortech-faq-read-this-before-asking-vortech-questions.html
Old Oct 31, 2007 | 03:44 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
ALREADY have, thanks
Old Oct 31, 2007 | 03:55 PM
RA11325's Avatar
RA11325
If you can keep belt-slip in check, the 2.87 pulley should probably do it.
Old Oct 31, 2007 | 04:09 PM
sentry65's Avatar
sentry65
the burninator
a smaller exhaust and smaller pulley will raise the psi
if you're wanting more power though, that's different
look into a T-trim or a lot more exhaust/cams mods and more timing/high octane along with 2.87 and 34 cog pulley.
Old Oct 31, 2007 | 04:11 PM
Blackbird CPV35's Avatar
Blackbird CPV35
a 2.87 and a 34 tooth cog pulley should do the trick
Old Oct 31, 2007 | 04:16 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I dont know the anwer-but Im curious what is your car making for power now and at what boost level?
Ive heard that some Revups take longer to make power with Vortechs over other kits, are you happy with yours?
Old Oct 31, 2007 | 04:41 PM
DMK's Avatar
DMK
I'd just go with a T-Trim if you want that much boost. 2.87 and 34 Cog is going to get you there, but you will be overspinning the blower past its rated speed. More of a chance of blowing seals, damaging internals, etc.
Old Oct 31, 2007 | 05:49 PM
sentry65's Avatar
sentry65
the burninator
Lancers7705 and I have been PMing for about a week now discussing all this stuff.
I'm curious to see someone push beyond what other people have done, but if I remember right GTM thought the 2.87 +34 cog pulley shouldn't go much beyond 6700 rpms. I have no doubt that setup will go to 7100 rpms, but for how long it'll do it, no one knows.
hehe I feel kinda conservative now with my car, reving the just the 2.87 only to 6600 rpms
Old Oct 31, 2007 | 06:06 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
100% honest Alberto, NO, for as much money as I spent I was expecting MUCH more. Althought to be fair I was expecting what I felt in a test drive of a G35 running at the time (i didn't know) 14psi on procharger. That made me want a supercharger to find out I was running 7 psi and numbers are well not happy with either at the time but hopefully better after this increase. I have the nismo exhaust sentry and Dave is going to turn my rev limiter down a bit as I am running 550cc injectors. So I am definetly excited for this
Old Oct 31, 2007 | 06:07 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
oh and will probably get meth injection in the near future
Old Oct 31, 2007 | 06:27 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks for the honest opinion...
Old Oct 31, 2007 | 06:30 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
np, hopefully will get my $ worth at 12-14psi, Hello my name is Bryce and I am an addict (Boost)
Old Oct 31, 2007 | 08:08 PM
sentry65's Avatar
sentry65
the burninator
i still think there's something else going on if you're only hitting 7 psi on a REV UP engine with a 3.12 pulley. Nismo exhaust is better than stock, but it won't flow THAT much more. I kinda wonder if there's a possible exhaust leak or if there isn't more work that can be done with the tune?
Old Nov 1, 2007 | 04:55 AM
booger's Avatar
booger
To get to 13-14psi with a Vortech . You wiill need the T-trim blower , the 2.87 pulley or a 34toothed cog pulley and the 3.12 serp . I was the first one [ I believe ] to do this and I did the 34 tooth cog and the 3.12 . Reason being the bigger serp pulley had more area to grip the serp belt . With the stock intercooler and pipes , you should reach 13psi somewhere around 6300rpm . With a rev up motor I wouldnt think there would be much difference unless there is more over lap with the valves .
Going to a larger intercooler and pipes I was able to get to 13psi at 5900rpm . But I still had the same results . The serp belt will slip the rest of the way to redline . The reason is , the blower gets harder to turn as the PSI builds and when it gets to a certain point [ 13psi ] the serp belt no longer holds . It ends up slipping , grabbing , slipping , grabbing....till redline .
I have gone to a all cog belt set up to be able to build boost all the way to redline . It stil is a work in progress , but Im real close . Mounting a larger Bypass [ BOV] and intercooler changes , and a new EMS and it will be finally done .
Be glad to help if I can....Bill
Old Nov 1, 2007 | 07:43 AM
jouvert00's Avatar
jouvert00
I make 13 psi @7100 with the 34 tooth cog pulley & the 3.12 serp pulley.
Old Nov 1, 2007 | 10:15 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
the rev ups have different pulleys on the cog side.
they come with the 3.12 pulley on them already.
all you need is the 2.62 pulley and a good tuner. thats it.
the 2.87 pulley on there will make right between 10-11 psi on a revup
Old Nov 1, 2007 | 10:43 AM
sentry65's Avatar
sentry65
the burninator
what cog pulley do the rev up kits come with? how many teeth?
Old Nov 1, 2007 | 11:00 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
oh so 2.62 do i need to do the 34 tooth rear cog pulley? (with stock 3.12 I am making 7 psi in the heat and on a nice COLD day 8, so 2.62 will definitily make 11-14 psi)?
