driving turbonetics st on no tune...
Old Nov 19, 2007 | 01:19 PM
bbs350z's Avatar
bbs350z
Default driving turbonetics st on no tune...
i got a turbonetics set up without the reflash. im getting my utec tuned at GRD in chicago. its roughly 90 miles away. could i safely (and slowly) drive the z from milwaukee to chicago to get tuned? this is defiantely a last resort if i cannot find a trailer to take the z in, but if need be, could it be done?
Old Nov 19, 2007 | 01:21 PM
athenG's Avatar
athenG
Is everything installed? why not load a base Map and start with that.
Old Nov 19, 2007 | 01:33 PM
accordfreak's Avatar
accordfreak
just take out the wastegate spring. you'll have zero boost pressure.
Old Nov 19, 2007 | 01:35 PM
str8dum1's Avatar
str8dum1
the biggest issue is in the injectors (assuming you put in bigger injectors ). they will need to be scaled to make the car driveable. otherwise, stay off boost and below 60% throttle (or whatever your threshold setting is in the UTEC) the car's oem ECU will control everything
Old Nov 19, 2007 | 01:43 PM
QuadCam's Avatar
QuadCam
I drove around with my TN kit on stock injectors and stock ecu for a couple weeks. Just stay out of boost. (i.e don't floor it!!!!) You can go to 1-2 psi without an issues, but don't push it!!!! you can drive on highway around town, etc....it won't be a problem.....But again, Don't accelerate hard enough to start spooling the turbo!!!!
Audible Mayhem's Avatar
Audible Mayhem
My350z
you will run really really rich, if you can keep it running you can do it if you stay under 25% throttle...
Old Nov 19, 2007 | 01:52 PM
bbs350z's Avatar
bbs350z
im running 440cc injectors, and plan on shifting below 2500. im most likely getting a triler, but just to be sure.
athenG, where can i load a basemap?
Old Nov 19, 2007 | 02:54 PM
VIZAGE's Avatar
VIZAGE
Everyone seems to say it will be ok under certain conditions. But you already must have spent several grand. Go for the couple hundred to have it hauled there. Good luck with it all. Give us an update after it's tuned?
Old Nov 19, 2007 | 04:00 PM
athenG's Avatar
athenG
Go to Turboxs.com site and download the base map for your kit (TN)
http://www.turboxs.com/utec350zupdate.htm
Not sure if the base map uses 380CC injector so you may need to scale it. I do see a 550cc base map though.
Check this thread and it will guide you on how to scale your injectors.
http://g35driver.com/forums/showthre...reddy+base+map
Old Nov 19, 2007 | 04:29 PM
eltness350's Avatar
eltness350
The Untouchable
hey homie i drove to chicago no prob on a tune from my procharger setup!!...lol just dont go into boost!!.. let me know if u need anything since i wasnt there for the install i have been crazy busy...take care...
Old Nov 19, 2007 | 04:44 PM
athenG's Avatar
athenG
He is running a 440 inj so he'll run pig rich if he doesn't scale those injector. One other way is just un-install the 440 and bring back your stock injector.
Old Nov 19, 2007 | 06:35 PM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
The stock widebands should be able to handle 440s
Yes, you should be ok driving from milwaukee to chicago on 440s, try to stay out of boost, especially in the higher gears.
Old Nov 19, 2007 | 07:01 PM
QuadCam's Avatar
QuadCam
just put your stock injectors back in......it should take about 1/2 an hour to swap them back in!
BTW, you can shift at 7000 rpm if you want to. pretty much, you can accelerate as fast as your car was in NA form.....just don't spool the turbo up. It is very easy to drive the car without going into positive psi.
Old Nov 20, 2007 | 03:14 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Do not go into boost at all.
Old Nov 20, 2007 | 03:23 PM
athenG's Avatar
athenG
Look easy but I have a hard time not hitting boost. Maybe it's my foot but for me to do it, I can't press my gas more than 25% and I have to keep an eye on my boost gauge all the time.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
