Vortech fitment question for RevUp owners.
Old Nov 20, 2007 | 08:52 AM
Hexxum001's Avatar
Hexxum001
Default Vortech fitment question for RevUp owners.
So I was backing out of my driveway, I have to take it at an angle cuz my driveway is kinda steep and I scrape my TS front end. So this morning I guess I took too aggressive of an angle and it made my G kinda teeter (sp?) and when this happened, it made the body of my G flex a bit. When it flexed, I heard this crazy noise like something was rubbing. I drove to work and everything was fine. When I got to work I popped my hood just to check and I saw that the crankshaft pulley had rubbed up against the piping for my SC when the body of my G flexed. I could see the mark left on the piping. Is the crankshaft pully supposed to be that close to the piping?? If I had to take a guess I would say it's like a mm or 2 clearance. I turned my G on and it doesn't rub but damn, is it supposed to be that close?
Old Nov 20, 2007 | 09:08 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
ill look at my clearance. It may give an idea of what its like.
It wont be the best comparison, since i have a non revup Z and you have a revup G.
Old Nov 20, 2007 | 09:17 AM
Hexxum001's Avatar
Hexxum001
Okay, cool. I'm not sure if the piping is the same for both kits but I'm pretty sure the crankshaft pulley is in the same place for both engines. I was just really suprised to see how close the piping is to the crankshaft pulley. I mean, I've inspected my engine bay before just to make sure everything looks good but I guess I never really paid attention to the fitment. I might have to loosen the piping and see if I can pull that pipe a little bit further away from the crankshaft pulley.
Old Nov 20, 2007 | 09:40 AM
G35asian's Avatar
G35asian
For my nonrevup, its just however I position the charge pipe as to how close it is to the crank pulley. I say to just loosen the couple and shift the pipe to be away from the pulley, then you should be ok.
Old Nov 20, 2007 | 10:16 AM
Hexxum001's Avatar
Hexxum001
Yeah, that's what I'm gonna have to do. It's just way too close to the crankshaft pulley.
Old Nov 20, 2007 | 03:41 PM
harogts's Avatar
harogts
mine is about 3/4inch away from the crank, so its tight. it sits right against the fan
Old Nov 20, 2007 | 04:04 PM
z2g's Avatar
z2g
I have the non revup on my g and when I first installed the s/c the piping did rub on the crank pulley. It took me awhile to adjust it but now its sits barely off the pulley, but it doesn't rub any more
Old Nov 20, 2007 | 07:29 PM
Hexxum001's Avatar
Hexxum001
Damn, yeah mine is too close. I had to brake kinda hard on my way home and I heard the piping hit the crank pulley again. Thank god for the long weekend. I'll get a chance to adjust the piping. It doesn't rub while I'm driving, just if I brake hard or have to take a steep driveway at a crazy angle.
Old Nov 21, 2007 | 03:54 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
you will need to loosen the clamps and pry it towards the front of the car with a pry bar and then tighten them back.
thats what we do.
Old Nov 21, 2007 | 04:44 AM
booger's Avatar
booger
Mine has rubbed several times and a little adjustment is all it takes . Mine is getting close to being a hole in the pipe....lol
Old Nov 21, 2007 | 08:19 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
rev-up kit here, yeah mine has some nice dings in the piping also
Old Nov 21, 2007 | 01:04 PM
Hexxum001's Avatar
Hexxum001
thats what we do.
Thanks Jeremy. I'm gonna try to do it myself. I have a messed up back so I don't know how successful I'll be. If i can't do it, I already called GTM and they said just to bring it in on Saturday and they will take care of it.
Old Nov 21, 2007 | 01:05 PM
Hexxum001's Avatar
Hexxum001
Damn bro, yeah there really is practically no room down there huh?? I'll have to make sure to check that everytime I check my oil.
Old Nov 21, 2007 | 01:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
ive got a decent bit of clearance. Maybe .5 inch. My pipe is hugging the fan shroud. Then again, non revup 350z.
Would something like that be covered under the vortech warranty or is it an installer issue? Sounds like a mixture of both to me. The installer shouldnt have to use a pry bar to get the pipe to fit right because vortech didnt get the pipe bent out of the way.
Old Nov 21, 2007 | 01:15 PM
Hexxum001's Avatar
Hexxum001
That's a good question bro. There is not much room at all down there but it looks like there is room to move it about half an inch or so. That should be more than enough.
Old Nov 23, 2007 | 07:22 PM
Hexxum001's Avatar
Hexxum001
Yup I had a pretty nice ding on the piping of the SC from the crankshaft pulley. I loosened the fittings and was able to pull the pipe away from the crankshaft pulley enough for there to be about 1/2 an inch or so of distance. That should be cool for now. I'll definitely have to keep an eye on it though.
sales@czp
Sep 23, 2019 03:30 PM
