Can someone explain Ambient Temp and IAT.
Old Nov 20, 2007 | 12:56 PM
athenG's Avatar
athenG
Default Can someone explain Ambient Temp and IAT.
We all have FMIC to cool down the compressed air coming from our turbo/SC right. I'm not sure how accurate the IAT temp that I'm getting from Utec/ECU coz it is really damn close to the outside Temp.
When I did my logging at 55F, my IAT is usually around 14C. When I did some logging when the outside temp was 47 then my IAT is around 8C. When I did some logging at around 36F then my IAT is between <1 to 2C.
My IAT is really close to the outside temp. How close are your IAT to the outside Temp?
Old Nov 20, 2007 | 02:30 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
1-2 deg C is lower than 36 deg F.
Are you taking measurements while cruising or while under high levels of sustained boost?
Is your IAT sensor in the intake flow stream behind the compressor?
Old Nov 20, 2007 | 03:02 PM
athenG's Avatar
athenG
Not sure how utec get it's IAT. I thought this all come from the ECU? the numbers are from a low of boost around 3-4psi and pretty much the same even at cruising. I have a rear-mount Turbo so it does help improve the IAT but damn I'm pretty much dead even with the outside temp Maybe it's my TopSecret Front Bumper STS do claim that they have almost 90-97% efficiency with their FMIC.
Old Nov 20, 2007 | 03:09 PM
QuadCam's Avatar
QuadCam
you won't see a big spike in air temps from 3-4 psi.....and all that piping with the rear mounted turbo will also lower the charge air temps. Combine that with an intercooler, and you will really see low IATs.
Old Nov 20, 2007 | 03:14 PM
athenG's Avatar
athenG
I just wish UTI can fix my problem so I can also log my IAT while I'm at WOT. Every now and then if I have a passenger I would ask them to telnet to UTEC just to see my IAT coz UTI Dashboard don't work for me
Old Nov 20, 2007 | 05:34 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
+1...and the IAT input comes from the MAF sensor if using the UTEC, in case the OP was wondering.
Chris350z03
Oct 8, 2023 07:19 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
irishguy0224
Sep 22, 2015 06:57 PM
Shane86
Sep 17, 2015 05:33 PM
