Advantages of Raising Rev Limiter on 5AT
Old Nov 26, 2007 | 06:33 PM
acg's Avatar
acg
I have the L flash from technosquare which raised my limiter to 7100
Old Nov 27, 2007 | 06:36 AM
rcdash's Avatar
rcdash
Originally Posted by helldorado
Pre 04.5 is a hard limiter. You bounce off of it, but the engine maintains power for the most part. 04.5+ is a soft limiter where it cuts fuel and pulls timing. So the engine slows down before hitting redline and doesn't bounce.
Actually I have an 04.5 and it is a hard limiter (i hate hitting it). My understanding was 05 and up is the soft limiter... (for G35 anyway, not 100% sure about the Z)
Old Nov 27, 2007 | 06:54 AM
helldorado's Avatar
helldorado
Is it a hard on the 04.5? I know certain aspects of the tranmission and ECU were changed for VINs 800001 and up, I was under the impression the soft limiter was one of them. But yeah, definitely there on the 05 as that's what I have.
Old Nov 27, 2007 | 07:06 AM
rcdash's Avatar
rcdash
My VIN is 820... and it has the TCM embedded in the VB like the newer trannys. The rev limiter is very hard - very embarrassing to hit it trying to pass someone (and a bit dangerous because it's hard to shift with the car bucking like a 2 yr old throwing a tantrum)
Old Nov 27, 2007 | 08:09 AM
helldorado's Avatar
helldorado
Good to know, then its definitely 05+.
Old Dec 4, 2008 | 06:59 PM
G35cTT's Avatar
G35cTT
Wonderin if anyone knows if you need to retune fcon if you get the limited spec flash that removes the RPM and speed limiter?
Old Dec 18, 2008 | 08:17 PM
minus500's Avatar
minus500
Nope.
Old Dec 19, 2008 | 12:45 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Even with a raise rev limiter, the stock shift points are unchanged. But, if you are boosted, it gives you a bit of a buffer between the time the ECU starts pulling timing and fuel if on a stock VB and it can't complete the shift before you would hit the stock redline vs having it raised.
In manumatic mode, you can take full advantage of the higher redline.
Originally Posted by Motormouth
you have to use Manual mode otherwise it shifts at the stock points.
Originally Posted by coachk
Mine is raised to 7200 and I shift at 7k in tip mode when racing
You get the best of both worlds IMO by raising the rev limiter.
I don't mind that the stock shift points remain unchanged in regular auto mode. That will be just fine for when I'm daily driving or regular street/highway commuting. In those situations, I wouldn't be getting on the boost hard or revving it high anyway.
When I'm doing any "spirited" driving or I'm at the track, I'll use the manual mode through the Works Bell column shifters to take full advantage of the raised redline. In preliminary discussions with Jason Siebels a while back, we talked about setting redline at 8000 or 8500RPM. Once my build is complete and we're ready to have him tune it, I'll go with whatever his recommendation is.
Old Dec 19, 2008 | 03:36 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I think Bert had a couple too many beers that night ......You would of definitely felt the fuel cut off at 7500 rpm based on your stock rev limit.
IIRC in auto mode I have also had it shift after the stock rev limit setting so I figured it was because my rev limiter was raised.
Im telling you Bert wasnt drinking and i wasnt either.I -We never hit the fuel cut off.I dont have any reason to bullsh!t i can still do it to this day and i dont know why.
