Vortech is 98% complete! Questions about some random odds and ends.
Old Dec 9, 2007 | 10:09 PM
Everybodywildou's Avatar
Everybodywildou
Default Vortech is 98% complete! Questions about some random odds and ends.
1. My bypass valve is making some strange sound at certain RPM. It sounds almost like squealing brakes. What is the cause of it? How can I fix it?
2. On the stock intake, there is a hose that connects to it. I think its for the EGR or something. Where does it go to now? Should I put a filter on it or something?
Old Dec 9, 2007 | 10:11 PM
Nexx's Avatar
Nexx
hose on the filter, as for the sound, not sure what to make of that.
Old Dec 9, 2007 | 10:42 PM
DMK's Avatar
DMK
1) Adjust your bypass valve to show 6-7 threads above the locking nut.
Old Dec 10, 2007 | 12:36 AM
Everybodywildou
Adjusted it to 6. Still does it for a split second between 800rpm - 1000rpm
Old Dec 10, 2007 | 03:07 AM
Mr_pharmD's Avatar
Mr_pharmD
adjust a few more
Old Dec 10, 2007 | 03:45 AM
jpc350z's Avatar
jpc350z
That hose may be the air breather hose that goes on the back of the vortech filter..
Old Dec 10, 2007 | 04:30 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
you are supposed to extend that hose to the side of the filter on the blower. that sound is normal out of the BPV. you can add a filter from vortech that cuts down on it a lot.
Old Dec 10, 2007 | 06:33 AM
MUZZY's Avatar
MUZZY
1- to get rid of sound try showing 6-7 threads on the BPV, or increase your idle to 1k rpm
2- that is your breather hose for your driver side crank case. it is suppose to be hooked up to the air filter. if your not going to do this you need to put a small filter on it.
Old Dec 10, 2007 | 12:13 PM
Everybodywildou
okay so I'm only showing 6 threads and it still does it. Tighten it some more? I'm afraid it wont be open as much as it should be at idle.
Old Dec 10, 2007 | 03:11 PM
Everybodywildou
ttt
Old Dec 10, 2007 | 03:12 PM
iStan's Avatar
iStan
ZR
Originally Posted by Everybodywildou
ttt
Try to get a recording of it. The Vortech makes all sorts of funny noises.
Old Dec 10, 2007 | 03:32 PM
Everybodywildou
Well in this guys video, it makes the same sound mine makes at 0:33. It sounds like brake squeal.
http://www.panhandlez.com/v2.wmv
Old Dec 10, 2007 | 07:20 PM
Everybodywildou
anyone? Should I go down to 5 threads or is that too tight?
Old Dec 10, 2007 | 07:24 PM
iStan's Avatar
iStan
ZR
I'm in the library. I'll listen to it later tonight and comment.
Old Dec 10, 2007 | 10:40 PM
Everybodywildou
Thanks man I appreciate it.
Old Dec 10, 2007 | 11:14 PM
iStan's Avatar
iStan
ZR
Mine makes that high pitched sound as well. I believe it is just the frequency. Is it the same sound at the end of the vid as well?
Old Dec 11, 2007 | 12:07 AM
Everybodywildou
Yep same sound. I think it may eventually drive me crazy. lol
Old Dec 11, 2007 | 12:14 PM
Everybodywildou
After driving around today, I noticed that when cruising in first or second, it sounds like a lot of air is coming out of the bpv. Does that mean my bpv is too loose? I'm only showing 6 threads by the way.
Old Dec 11, 2007 | 12:17 PM
iStan's Avatar
iStan
ZR
Check with a boost gauge, but I will say the mother f'er is LOUD anyhow. You're probably doing fine, just make sure you don't have compressor surge.
Old Dec 11, 2007 | 04:06 PM
Everybodywildou
Yeah I hear a few people with the vortech kit has this problem. It's just that the noise annoys me. lol
