Guys with built engines, what are your vacuum readings?
Old Dec 17, 2007 | 08:26 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Default Guys with built engines, what are your vacuum readings?
I searched and found only few info on it. With a stock engine, my vacuum number was in the -20mmHg during the idle. But now with a built engine, when the engine is cold, it's in the low -17~ mid -18s. Once the engine warms up, the reading is in the mid -18s to low -19s.
Is it normal to have vacuum readings change by the temperature or do I have a vacuum leak? Also, seems as though -18 is about the average vacuum readings for the built engines, why is that?
Old Dec 18, 2007 | 04:57 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
I don't know this answer, but I would think it was because of the lower compression on the engine. My stock block held vacuum at 21-23 and fluctuated midly in colder weather, but never under 21.
No with that said, I think I remember someone telling me that 15-18 mmHG was normal with lower compression.
Old Dec 18, 2007 | 06:43 AM
chris'smax's Avatar
chris'smax
hmm my car only gets about 10 hg at idle. This reading comes off my hks evc VI
Old Dec 18, 2007 | 07:53 AM
gothchick's Avatar
gothchick
Mine is @ -18.1 at idle, and @ -17.4 under load near redline using UTEC data logs. I haven't data logged my engine while it was cold, so I'm not sure what the vacuum reading would be cold. My compression is @ 145 +/- across all cylinders.
Old Dec 18, 2007 | 09:05 AM
Old School's Avatar
Old School
Shift_Boost
I think its normal....at warm up I'm at the same as chris...but once its warm it goes to 18-20. 8.5:1 compression here.
Old Dec 18, 2007 | 09:43 AM
Zivman's Avatar
Zivman
That sounds about right.
Old Dec 18, 2007 | 09:52 AM
06blueZ's Avatar
06blueZ
How could your vaccuum be at -17.4 under load? Under load or WOT it should be at 0 or + if you are FI...
Old Dec 18, 2007 | 09:55 AM
Old School's Avatar
Old School
Shift_Boost
If I don't hammer the gas, I can stay in vacuum all the time.
Old Dec 18, 2007 | 10:45 AM
gothchick's Avatar
gothchick
Sorry, should have been more clear that I'm NA.
Old Dec 18, 2007 | 04:23 PM
Weqster's Avatar
Weqster
Its normal. The vac flucuates because as the temp of the engine rises, the rings seal better.
Old Dec 19, 2007 | 05:33 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I have both Zeitronix and the HKS EVC VI. When my Zeitronix reads -18~-20s, HKS EVC VI reads about -8~-10s. I think the HKS EVC VI boost sensor isn't as sensitive or something..
Old Dec 19, 2007 | 08:20 AM
QuadCam's Avatar
QuadCam
The HKS is reading its vacuum in PSI, not in inches of Mercury. the conversion is roughly 1psi equals 2 inHg. so backsically, 9 psi of vacuum equals 18 inHg.
Old Dec 19, 2007 | 08:25 AM
Biochem7's Avatar
Biochem7
Regular
Yeah the UTEC is weird about this, if you look at the dashboard it reads -9 psi at idle? Its basically just saying 18 inHg of vacuum.
liqalu04
Jan 2, 2022 12:58 PM
35reilly
Sep 28, 2015 07:42 AM
