Z Oil Pressure Gauge Sender Location
Old Dec 22, 2007 | 08:06 AM
MardiGrasMax's Avatar
MardiGrasMax
Default Z Oil Pressure Gauge Sender Location
Doing the tear down for my build up and noticed that on my G35 blocks upper oil pan that their is a plugged port in the oil feed galley that goes to the heads. It sits on a 45deg angle of the pan behind the alternator/PS pump area. Is this where the factory oil pressure gauge sender goes on a Z? Thanks.
Old Dec 22, 2007 | 08:46 AM
QuadCam's Avatar
QuadCam
the oil pressure sending unit should be in the same location for the G and the Z..................down near the oil filter. The G has the sensor, but just doesn't have a gauge for you to view it.
Old Dec 22, 2007 | 09:26 AM
MardiGrasMax
The one by the filter is for the dash warning light for low oil pressure. Im pretty sure its just a low presure on/off switch. Im almost certain the Z has an additional sender for the factory pressure gauge.
Old Dec 22, 2007 | 10:02 AM
merlin3's Avatar
merlin3
i don't remember there being another sensor on my z when I put everything together. I think the only one is by the oil filter.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
