First thing to go..
Old Dec 24, 2007 | 09:21 AM
phat04350z's Avatar
phat04350z
Default First thing to go..
When adding FI what is typically the weakest part on the motor /trans to go? I am just speaking in the sence on buying a Greddy kit or some other kit and throwing it on. Rods? Pistons?
Old Dec 24, 2007 | 09:32 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Rods!
Do a search next time or else some members here will flamed the Hell out of you.
The Fi section take no prisoners!
Old Dec 24, 2007 | 09:33 AM
Philthy's Avatar
Philthy
Boost Junkie
Taking history into account, I would say connecting rods... but while you're in there pistons, L19 studs and a good head gasket... A clutch upgrade is a good idea as well...
Old Dec 24, 2007 | 09:44 AM
JETPILOT's Avatar
JETPILOT
Definetly the connecting rods are the weak link. If the tune is a good one the connecting rods will be the first to go. A bad tune and you will probably crack a ringland first.
JET
Old Dec 24, 2007 | 10:01 AM
tonester1011's Avatar
tonester1011
CF God
Rods...i learned that the hard way.
Old Dec 24, 2007 | 10:14 AM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Everything aside from the clutch in the Trans is quite strong. Engine wise, the rods are definitely the weakest link.. We made 550whp/600tq on a GT35R Kit from powerlab (stock engine) for a while, then when we turned the boost up past that we folded 5 rods
Old Dec 24, 2007 | 11:39 AM
JETPILOT's Avatar
JETPILOT
They will fail long before 550whp. I had a rod fail @ 410whp.
JET
Old Dec 24, 2007 | 01:06 PM
SpoilsofWar's Avatar
SpoilsofWar
One of these kids is not like the others...
Stock VQ rods; strong they ain't.
Old Dec 24, 2007 | 01:10 PM
SpoilsofWar
Right is included for free... Left costs about $500 or so (just the rods). It is not worth your block to be cheap when playing with high boost FI.
Old Dec 24, 2007 | 01:13 PM
Mike Wazowski's Avatar
Mike Wazowski
did anyone mention the rods being a weak point?
Old Dec 24, 2007 | 01:30 PM
JET MECH's Avatar
JET MECH
400 to 500 horse power numbers do not always take out the VQ's stock rod's. its the high tourqe numbers that bend these puppys. (turbos = full boost around 3000rpm's = high tourqe numbers = bent stock rod's.
Old Dec 24, 2007 | 04:13 PM
overZealous1's Avatar
overZealous1
hahha i think some were hinting at it, but no one has come right out and said it
Old Dec 24, 2007 | 04:16 PM
Jason333's Avatar
Jason333
hi
Those 2 images really do put it into perspective.
Old Dec 24, 2007 | 11:37 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
+1. It's not the same making 400 whp on a turbo and 400whp on a supercharger.
With a turbo, peak boost occurs at peak cylinder pressures (max torque), wheras a supercharger is only producing around 4 psi at that point.
Old Dec 25, 2007 | 04:04 AM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
I'd always heard the stock rods were pencil di*ked but that pic image makes the difference crystal clear. With that said I cant wait to save up for my engine build.
Old Dec 25, 2007 | 05:20 AM
GodSendsDeath's Avatar
GodSendsDeath
Its a long shot but I will bet my money on rods :P
Old Dec 26, 2007 | 04:57 AM
phat04350z's Avatar
phat04350z
If just getting a kit and leaving it at like 5psi (I am guessing that is what those kits come pre-set at) I would be fine correct?
Old Dec 26, 2007 | 05:10 AM
doug's Avatar
doug
who is doing the install and tune will answer that question..
i ran 400/400 on a install/tune from MRC in spotswood and everything was fine
Old Dec 26, 2007 | 05:11 AM
Mike Wazowski
just make sure you have money saved up for a new block. never know what is going to happen. FI is not cheap and you better understand that all sorts of things can and WILL happen. If you dont have an extra 10K in savings, it can hit you pretty hard.
a bad tune and it doesnt matter how little boost you are using...boom
Old Dec 26, 2007 | 05:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I agree with rods
I chucked 2 out of the side of my block at 390ft/lbs with a weaksauce set-up...BUT I Drive my car like sports car should be driven. Many FI members claim to drive hard and actually drive like my grandma. Take it for what its worth.
