Turbo HELP!!! Please.
Old Dec 26, 2007 | 08:55 PM
taurran's Avatar
taurran
Turbonetics sells a downpipe with a catalytic converter already installed. The part number you're looking for is: 21201
Contact your local Turbonetics dealer or one of the dealers on this board and they can order it for you immediately.
That way you can swap it out whenever you need to get tested....
Old Jun 12, 2008 | 05:25 AM
doug's Avatar
doug
Originally Posted by doug
smog? in CT? all they are suppose to do is hooked up the ODBII scanner and check for codes.. what the hell? smog?
I just went through CT emissions last Saturday.. they actually do a visual inspection for your cat
Old Jun 12, 2008 | 06:27 AM
SlideFox's Avatar
SlideFox
Damn.... sounds like some states are getting a little to smart! Do you know if all locations in your area are doing that or was it that one particular person. Sometimes you get a douchebag inspector!!
Old Jun 12, 2008 | 06:34 AM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
If you have a Z, it seems like everybody wants to get a piece of you! this happens to me all the time!!! lucky enough i got a place in vegas that can hook me up for a bill how about getting a high flow cat and get em wielded? I bought a hi-flow cat and the actual cats are half the size of the OEM ones, it might fit... good luck bro, let us know any updates...
Old Jun 12, 2008 | 08:06 AM
SpoilsofWar's Avatar
SpoilsofWar
So... how did it go when they saw you had none?
Old Jun 12, 2008 | 11:08 AM
doug's Avatar
doug
i got some.. my SuperDooper Shop MRC sent me a set of cats at no charge to do emissions..
doug's Avatar
doug
no.. all CT shops are doing it.. its on the standard CT Form from the DMV
Old Jun 12, 2008 | 11:30 AM
str8dum1's Avatar
str8dum1
end thread!
Old Jun 12, 2008 | 03:41 PM
SC 350Z's Avatar
SC 350Z
like taurran said buy the down pipe with the cat it will solve all your problems plus i have the down pipe with no cat and have been boosted on the TN for 1000 miles and was on the procharger for 10,000 miles never once threw a code for a o2 sensor check the sensors they do go bad!!!!
Old Jun 12, 2008 | 05:03 PM
doug's Avatar
doug
Originally Posted by str8dum1
end thread!
i just wanted to bumped this thread to clear up the misinformation i gave him prior.. just incase he decided to listen to me instead of buying the downpipe with the cat..
Old Jun 12, 2008 | 08:27 PM
350 Rookie's Avatar
350 Rookie
Damn you guys brought the dead thread back to life.
My story went like this. I searched and found some guy giving out 2 cats and a y pipe for free so i jumped on the deal. Took off the cross over TN exhaust pipes and put on the stock cats and Y pipe and went through. Right after emissions, i came home and put the turbo pipes back on. *** the LAW!!!!! lol
Old Jun 13, 2008 | 08:36 AM
ekelly36's Avatar
ekelly36
lol
Chris350z03
Oct 8, 2023 07:19 PM
