UltimateRacing T3-super60 TT problem.
Old Jan 27, 2008 | 12:44 PM
aalzuhair's Avatar
aalzuhair
As I said, I'm sorry to hijack your thread, but technically that kit is mine <?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype class=inlineimg id=_x0000_t75 title="Stick Out Tongue" alt="" border="0" src="/forum/images/smilies/tongue.gif" smilieid="6" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o<img></v:shapetype>
Anyway, if you want to know about your turbo kit, you should talk to UR, because the turbo kit that Ahmed took from me is not the same as yours (Different turbos, most likely).
At any rate the turbos that you have should be able to produce 600whp with a good tune but it all depends on how UR setup the turbos for you (i.e. A/R, wheel size, ported or not, etc.) ... At the end of the day you can change the turbo wheels/setup/trim and you will be good to go
Old Feb 5, 2008 | 08:00 AM
q8pianist's Avatar
q8pianist
thanks AZ .
i have a bad luck with the kit and the clutch.
the clutch is allways slipping from the first time i install it.
and the car still didnt make the 600whp.
to be honest,
i didnt forget about the money.
but u still owe me a 700whp turbo kit !!!
any way ill sale the kit.
Old Feb 5, 2008 | 08:02 AM
q8pianist's Avatar
q8pianist
ill post the 17psi Dyno very soon and we can talk about the timing map if u like. just to make sure everything is right.
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
samansharif
Sep 25, 2015 12:31 PM
