Adding extra injector on APS TT with 440cc
Old Jan 26, 2008 | 09:27 AM
noer's Avatar
noer
Default Adding extra injector on APS TT with 440cc
Hi guys,
Does anyone know what is the max power you can get out of APS TT kit with 440cc injectors if you add another injector. Is it possible to get 500whp with the walbro pump. I have forged internals.
Regards
Old Jan 26, 2008 | 09:28 AM
rookie's Avatar
rookie
Replace them all not just a 7th injector.
Old Jan 26, 2008 | 10:58 AM
Zivman's Avatar
Zivman
Originally Posted by noer
Hi guys,
Regards
On stock compression, the supplied injectors should get you darn near 500. If you have a dropped compression setup, they will get you to around 450. I would rather replace them with bigger injectors all around vs adding a single injector. I would think you could add another injector and get to 500, but again I think a set of deatschwerk 600's might be a better way to do it
Old Jan 28, 2008 | 04:46 AM
noer's Avatar
noer
I am running 9:1 compression and still have the Unichip setup. For the deatschwerk 600's would I need to change my Unichip?
Old Jan 28, 2008 | 05:28 AM
Zivman's Avatar
Zivman
only your tuner can tell you that... we will be trying this exact setup on a friend of mine's boosted G35 in about a month or two when we get his motor together. My tuner thinks it is plenty doable. If you want to hold out till then we can try it out first
Old Jan 28, 2008 | 02:03 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Noer, it is time for some bigger injectors and a Haltech like your friends. We have both in stock with your name on them
Old Jan 28, 2008 | 02:55 PM
IIQuickSilverII's Avatar
IIQuickSilverII
apex locator
Jul 23, 2021 02:27 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
