Vortech dynojet numbers on (stock block)
Old Jan 29, 2008 | 09:38 AM
jouvert00's Avatar
jouvert00
Default Vortech dynojet numbers on (stock block)
I have a non rev up motor (stock block) dynoed last week on a dynojet, it was pretty cold out that day which prolly accounted the 14psi we saw @ 7100.Made around 380whp on the dyno dynamics.
MODS:3.12P/34 tooth cog/strup headers/stillen td exhaust/hfc's/650cc inj/aam rfs/utec.Tuned by dave @ Function tuned.
Old Jan 29, 2008 | 09:54 AM
jpc350z's Avatar
jpc350z
Great #'s. the A/F seems a little rich. What were the #'s on the Function Tuned Dyno for comparo?
Old Jan 29, 2008 | 10:21 AM
jouvert00's Avatar
jouvert00
I have to find those dyno sheets,i agree ist's pig rich although that day could have been in the mid 30's and maybe the utec dumped a bunch of fuel to compensate for the conditions
Old Jan 29, 2008 | 10:28 AM
Nexx's Avatar
Nexx
you must have a freak of nature because most cars with that same setup dyno below 400whp. i dont even think 14psi is even physically possible for the 3.12 pulley. you sure you dont have a 2.87? congrats on the fantastic numbers.
Old Jan 29, 2008 | 10:30 AM
sentry65's Avatar
sentry65
the burninator
he's reving the engine to 7100 rpms on a non-REVUP engine, that's why the psi would be high
good numbers
Old Jan 29, 2008 | 10:40 AM
rx7/350z's Avatar
rx7/350z
Stock block plus 14psi plus 7100rpm equals kaboom!!!!!!!!!!!!!
Nice numbers keep reving it that high and it won't last long
Old Jan 29, 2008 | 10:43 AM
jksstar's Avatar
jksstar
very good #s man
good numbers
I rev mine (03) to 7000 and only see 13psi with the 2.87. What would make the 3.12 pulley make more boost the the 2.87? Not trying to go off topic
Old Jan 29, 2008 | 11:19 AM
sentry65's Avatar
sentry65
the burninator
Originally Posted by jksstar
very good #s man
it depends on the exhaust/engine/intake flow and the rpm you rev to
elevation and ambient air temp can change the psi a little too
I kept my redline at 6600 rpms @ 11 psi. If I had Sam@GTM take it up to 7000, IMO I'd be asking for trouble in the long run even though I might reach close to 13 psi
Old Jan 29, 2008 | 11:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
His car def makes power running mid 12's on stock tires, excellent for a heavier G
Old Jan 29, 2008 | 11:35 AM
jouvert00's Avatar
jouvert00
I very seldom hit 7100 i just had him tune it like that in the rear event that i may hit the rev limiter, if you look at the graph around 6600-6700 it starts to fall off a tad that's where i normally shift.
But thanks for the encouraging words
Old Jan 29, 2008 | 11:42 AM
jouvert00's Avatar
jouvert00
very good #s man
I also have the 34 cog pulley installed which would account for the additional psi.
Old Jan 29, 2008 | 11:43 AM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
Great numbers. Congratz and have fun.
Old Jan 29, 2008 | 11:51 AM
jouvert00's Avatar
jouvert00
Thanks bro i am
Old Jan 29, 2008 | 12:20 PM
str8dum1's Avatar
str8dum1
good #'s!!
the 34T/3.12 cog/serp combo, essentially makes the same ratio as the stock 32t/2.87 combo. so dont let him fool you
you'll give us a good idea of longevity with an overspun impeller on an over-rev'd motor.
Old Jan 29, 2008 | 12:35 PM
Zridder19's Avatar
Zridder19
Nice numbers
Old Jan 29, 2008 | 01:54 PM
booger's Avatar
booger
Great to see this !!!!!
The 34 tooth cog gets you the extra psi for sure . Its a better pulley set up than the 32 tooth and the 2.87 . CONGRATS !!!!!!!!!!!
Also great to see guys post both thier load base dyno and dynojet numbers !!!!!
Hey Sentry
Let the guy have his post with out you saying....if you put this pulley on .....and rev to this rpm .......you would make XXXwhp . Just to let him know you still make more whp than he does . Give us all a break will ya ?????
Old Jan 29, 2008 | 02:04 PM
96sleeper's Avatar
96sleeper
I have been revving my stock 3.5 motor with cams to 7000 rpm with the 3.125 pulley for almost a year now and no problems, knock on wood. I am hard on it and take it to the track alot. Its in a maxima though which is a different setup, I am only getting a max of 8.5-9psi from the 3.125. I think the IC robbed me of around 1-1.5 psi. I have a 2.70 pulley I will be trying soon.
I think the boost doesn't hurt anymore than the rpm's do on the rods. RPM and torque is what is hardest on rods, vortech's don't make any torque except at peak VE, and many N/A people rev to 7000rpm, as did I for a year prior to the S/C. What I am trying to say is that if its ok to rev to 7k on stock rods, boost won't change that much, because the rpm is what is hardest on rods. (assuming a good tune with no detonation)
Old Jan 29, 2008 | 02:34 PM
sentry65's Avatar
sentry65
the burninator
Originally Posted by booger
Hey Sentry
OMG you would take it as bragging. I'll remove the whp estimate then since that bothers you so much.
I was mainly trying to caution about reving 500 rpms higher than redline with boost and trying to show that 13-14psi would be completely possible for the people that weren't sure how 14 psi could be made with the SC-trim
Old Jan 29, 2008 | 03:04 PM
deanG35c6's Avatar
deanG35c6
Jouvert,
All your power is being made before or at 6600, so there's really no reason to go further than that. I also have my non rev G tuned to 7100, but I did it to avoid bouncing off the rev limiter. By the time I react, I usually wind up shifting at 6600 to 6800 rpm. Great numbers.
Old Jan 29, 2008 | 03:09 PM
sentry65's Avatar
sentry65
the burninator
actually he would accellerate harder by reving past 6600 rpms. Even though the hp drops, the idea is during the rpm range of each gear, you want the highest average hp
if he was shifting from 2nd to 3rd at 6600 rpms, he'd start at 4500 rpms which is obviously a lower hp there than at 5000 rpms.
If he instead shifted at 7100 rpms, he'd start his 3rd gear around 5000 rpms
so look at the hp curve on the graph and figure you were reving from 4500-6600 rpms, or 5000-7100 rpms.
That's for 3rd gear anyway. It's slightly different depending on the gear
see the comparison overlay below where both areas under the curve are overlayed on the left and you can see the higher rpm chart has more hp on average
Attached Thumbnails Vortech dynojet numbers on (stock block)-higher_redline.jpg
