Oil cooler/warmer removal.............
Old Jul 14, 2010 | 04:48 PM
  #181
Glex25's Avatar
Glex25
The De bolt has a range of 75-95 in-lb
The HR bolt has a 80 in-lb torque spec
Old Jul 22, 2010 | 04:38 AM
  #182
QuadCam's Avatar
QuadCam
I don't recall having to use any special tools with the oil cooler removal. It's been a long time since I did this mod though. I only remember everything being connected with hose clamps.
Old Jul 22, 2010 | 06:14 AM
  #183
str8dum1's Avatar
str8dum1
there is a special tool for those kinda clips, that dont slip off the tabs and bust your hands all up.. I use vice grips.
Old Jul 22, 2010 | 06:27 AM
  #184
06blueZ's Avatar
06blueZ
Originally Posted by archebald23
question guys, how do you exactly uncouple the quick oil cooler connector at the line to radiator connection without having to purchase a special tool.
are you talking about the Auto trans cooling lines that run into the AT radiator?
Old Jul 22, 2010 | 07:59 AM
  #185
Andrei's Avatar
Andrei
Anyone here have to use impact guns to take off any bolts? I have everything I need but need to know that before I start.
Old Jul 22, 2010 | 08:07 AM
  #186
Glex25's Avatar
Glex25
I use mostly hand tools since I have no compressor at my house.
If I do work on my car at my friends shop I use a Air Ratchet.
For this job no impact gun is needed
Old Jul 22, 2010 | 09:20 AM
  #187
DavesZ#3's Avatar
DavesZ#3
An impact wrench is nothing but an invitation to strip a bolt head off or destroy the threads in the aluminum block. I never use one except on lug nuts or other bolts/nuts that I know can handle it.
Old Jul 22, 2010 | 10:58 AM
  #188
Andrei's Avatar
Andrei
Ok thank you both. I'll go ahead with this over the weekend.
Old Aug 15, 2010 | 04:03 PM
  #189
Cux350z's Avatar
Cux350z
hatersgonnahate
Need to find a shop/someone who is willing to do this for me. I have all the parts just it seems like the local shops around here dont want to do it or cant.
Old Aug 17, 2010 | 11:45 AM
  #190
bikinilust's Avatar
bikinilust
the shops prob dont want to do this mod because of liability issues...seeing as how most shops never heard of this mod and dont know if it could potentially cause damage which will then bring headaches to them because the customer may try to say that the shop is liable because "They must have done something wrong".
Also, by doing this mod, isnt it considered messing with the emissions system? Because by deleting the "oil warmer/cooler" and radiator bypass hose the engine would take a lil longer to warm up, thus emitting more crap into the atmosphere
Old Aug 18, 2010 | 07:08 PM
  #191
QuadCam's Avatar
QuadCam
Yup......it would definitely be considered altering an emissions related item as it does affect cold start warmup times.
Old Aug 19, 2010 | 07:49 AM
  #192
Cux350z's Avatar
Cux350z
hatersgonnahate
Emissions is not a concern. Most of the people doing this mod have other items that affect emissions more.
And i live in SC, we dont do emissions testing.
Old Aug 19, 2010 | 08:53 AM
  #193
str8dum1's Avatar
str8dum1
what part cant you do yourself? Its just bolt and unbolt.. super easy.
Old Aug 19, 2010 | 08:55 AM
  #194
DavesZ#3's Avatar
DavesZ#3
This is not something that would show up under emissions testing. They look at the emissions of a car at operating temperature, not cold start.
I have a related question (related to coolant hose). Anybody add the adapter to the radiator for installing a coolant temperature sensor? If so, what size adapter fits the OEM hose? I believe the ID of the hose is 33mm so I assume something slightly larger (34, 35mm) would be desired so that the hose fits tightly before clamps are applied.
Old Aug 19, 2010 | 10:45 AM
  #195
str8dum1's Avatar
str8dum1
34mm would work (http://www.glowshiftdirect.com/34-mm...ttachment.aspx). But those kinda sensor holders can be a pain if the sensor uses the threads to ground. Since the fitting is in the rubber hose (ie no way to ground itself), you have to run an additional ground wire and attach it to the body of the sensor somehow and run it to the engine block.
Better option is to drill and tap the rear coolant pipe.
Old Aug 19, 2010 | 10:54 AM
  #196
QuadCam's Avatar
QuadCam
Rear coolant pipe would be a good spot to tap. Keep the write length to a minimum too for a nice, clean install.
Old Aug 19, 2010 | 02:17 PM
  #197
Cux350z's Avatar
Cux350z
hatersgonnahate
the welding part.
Old Aug 19, 2010 | 03:39 PM
  #198
str8dum1's Avatar
str8dum1
anyone with a mig can do that. my buddy did mine in his garage with a simple lincoln mig.
just cut off the pipes and lay bead on top of each other.
or, just cut the parts off and drill and tap. you can do that at home with hand tools.
Old Aug 27, 2010 | 01:38 PM
  #199
shiftdrift06's Avatar
shiftdrift06
Yeahhh, im not to good at welding either..
Do you guys know how much it cost to weld up the three nipples? (2 on the passenger, 1 on the driver?)
I went to welding/radiator shop, they quoted me 50 bucks, i think that is a little steep?
Old Aug 27, 2010 | 01:44 PM
  #200
QuadCam's Avatar
QuadCam
that's reasonable. welding doesn't come for cheap! My Lincoln Inverter tig is worth over $3000.
you may be able to get it done for less by checking around though. You never know when you will come across a welder in need of some coin!
