Question about 3.8L motors
Old Feb 13, 2008 | 09:19 PM
  #121
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by George@GTM
The 4.2L stroker isn't what runs hot, ANY sleeved VQ will run hotter than a non-sleeved VQ. It will run hotter (about 5-7 degrees Celsius) We made our fan kit to help any of the many sleeved VQ motors out there, or any other VQs that are tracked and see high temps.
The minimal heat difference will not be much of an impact on a daily driven car, plus our Fan kit and proper radiator will take care of the heat issues.
You do bring up another reason why it would be better to run our 3.8L stroker vs. a 100mm bore on sleeves, since our 3.8L stroker is not sleeved, it will run cooler.
Hope this helps,
-George
GT Motorsports
Dumb question here: I thought your 3.8L stroker was unsleeved. But I was looking at your engine packages ( https://my350z.com/forum/product-announcements/239093-gt-motorsports-short-long-blocks.html ), and you have the 3.8L stroker listed as a sleeved setup, why?
Old Feb 13, 2008 | 09:52 PM
  #122
redman333's Avatar
redman333
Originally Posted by JAMEZ
Dumb question here: I thought your 3.8L stroker was unsleeved. But I was looking at your engine packages ( https://my350z.com/forum/showthread.php?t=239093 ), and you have the 3.8L stroker listed as a sleeved setup, why?
I thought he had a 3.8 stroker with a 100mm overbore to make it a 4.1 liter. Obviously sleeved to get this.
Old Feb 13, 2008 | 09:55 PM
  #123
JAM3Z's Avatar
JAM3Z
Phenom
My bad. By "your", I meant GTM's 3.8L stroker motor setup. Not specifically George's.
Old Feb 13, 2008 | 09:58 PM
  #124
redman333's Avatar
redman333
Yeah your right, they have a unsleeved 3.8 stroker. I think they have both sleeved and unsleeved though. I can't remember.
Old Feb 13, 2008 | 10:41 PM
  #125
GTM's Avatar
GTM
Vendor - Former Vendor
This is correct, with the 3.8L you can go sleeved or unsleeved, up to you, but if you are going to sleeve it might as well go 100mm bore like me, unless you want to use HKS gaskets, then you cannot do a 100mm bore.
-George
GT Motorsports
Old Feb 13, 2008 | 10:46 PM
  #126
TheBlackPearlZ's Avatar
TheBlackPearlZ
thats the one thing i was wondering...cuz if you go HKS you are stuck with a 97mm bore. im guessing then george you just went with a cometic ??
Old Feb 13, 2008 | 10:49 PM
  #127
GTM's Avatar
GTM
I couldn't use HKS gasket regardless because of my 14mm head studs, so yes I went with a Cometic gasket to accommodate my bore and large head studs.
-George
GT Motorsports
Old Feb 13, 2008 | 10:51 PM
  #128
JAM3Z's Avatar
JAM3Z
Phenom
Thanks for clearing that up George.
Old Feb 14, 2008 | 07:10 AM
  #129
__jb's Avatar
__jb
Z + Rear Seat
Do sleeves also cause an NA motor to run hotter? I guess it stands to reason that they would. I don't really understand why sleeves increase the temperature of the motor. All the block material that is removed is replaced by the sleeves.
I live in Florida and am trying to determine if the 4.1L version would be acceptable for a daily driver. It gets pretty hot down here in the Summertime.
Old Feb 14, 2008 | 07:15 AM
  #130
sentry65's Avatar
sentry65
the burninator
the sleeves make the engine closed deck instead of open deck. Instead of the coolant completely surrounding the cylinder chambers, with sleeves, they only have little channels the coolant can flow through.
They're also not made of aluminum, but steel which traps in more heat
Old Feb 14, 2008 | 07:48 AM
  #131
Alberto's Avatar
Alberto
Cranky FI Owner
Iron
Old Feb 14, 2008 | 07:50 AM
  #132
sentry65's Avatar
sentry65
the burninator
oh I was wondering that after I wrote that. Iron's even worse that steel with trapping heat
Old Feb 14, 2008 | 08:30 AM
  #133
IIQuickSilverII's Avatar
IIQuickSilverII
...i dont think he needs to worry about it anyways with going with darton sleeves... if he is stroking his engine but keepign it N/A
Originally Posted by Alberto
Iron
werd
Old Feb 14, 2008 | 09:50 AM
  #134
__jb's Avatar
__jb
Z + Rear Seat
So you're saying that when they bore out the block for the sleeves, the outside diameter of the sleeves is so large that boring the block for it removes some of the water jacket that normally surrounds the cylinder?
I'm not sure what open/closed deck means.
Iron
Of course. I hadn't thought of that. It makes perfect sense now that you all mention it.
I am thinking of boring and stroking... hence the sleeve questions. Is Darton the only/best sleeve manufacturer?
I've been planning to bore and stroke a new RevUp NA motor for quite a while, but I never considered the possible overheating issues you all brought up in this thread. Very interesting.
Old Feb 14, 2008 | 09:55 AM
  #135
GTM's Avatar
GTM
The engine running a little hotter is not to be confused with overheating, we haven't had any overheating issues with our cars, also as mentioned a properly upgraded cooling system will take care of the higher temps.
-George
GT Motorsports
Old Feb 14, 2008 | 10:37 AM
  #136
gothchick's Avatar
gothchick
Great discussion! I'll be building my motor soon (staying NA), and am weighing the pros & cons of stroking to 3.8.
Old Feb 14, 2008 | 10:42 AM
  #137
sentry65's Avatar
sentry65
the burninator
just look at some shortblock pictures of a stock VQ35 and some darton sleeved short block pictures and you'll see
Attached Thumbnails Question about 3.8L motors-1169439374.jpg   Question about 3.8L motors-t_16225_01.jpg
Old Feb 14, 2008 | 11:18 AM
  #138
Alberto's Avatar
Alberto
Cranky FI Owner
Sleeving an NA motor would be OVERKILL IMO. 3.8L stroker, nice heads, and some spray for "special occasions" it would be a bad b!tch...
Old Feb 14, 2008 | 11:21 AM
  #139
thawk408's Avatar
thawk408
Would only sleeve an NA motor if I was going 4.2
Old Feb 14, 2008 | 11:24 AM
  #140
sentry65's Avatar
sentry65
the burninator
+1
and even then I still think I'd rather just go V8 for the money
