Took the plunge..... I'm going FI!!!
Old Mar 2, 2008 | 09:48 PM
  #41
JonnyC's Avatar
JonnyC
I'm just curious and making sure you are on the right track here - are you grinding 5th, or do you just have a hard time getting it in? Are we sure it isn't because of the shifter plate (not sure what it's called exactly) not being adjusted properly? If you press down on the shifter a bit when going into 5th, does it help?
Old Mar 3, 2008 | 03:01 AM
  #42
ChrisCJ99's Avatar
ChrisCJ99
It seems as though it is SOME kind of plate. Because it seems as though when I shift into gears, they "sit" kind of at an angle (if that makes any sense). Such as, the gears usually sit and move at a 90 deg angle. But instead it seems as though they sit at a 95 angle. But I don't GRIND my gears at all. I just have trouble getting it into gear. I tried putting it in gear while the car is shut off, and it went in 5th gear smoothly when I pushed down a bit!!! It REALLY seems as though there is just some kind of misalignment somewhere. The tranny seemed fine before I changed the clutch. The shop will let me know tomorrow. Thanks for the tip in the meanwhile!!!
Old Mar 3, 2008 | 06:01 PM
  #43
skn5002's Avatar
skn5002
So lets say you no longer had warranty... how much would it cost for the 009 tranny alone?
Old Mar 3, 2008 | 06:12 PM
  #44
Jay'Z's Avatar
Jay'Z
Originally Posted by taurran
People here just like to mindlessly repeat what they've heard because they don't know any better by saying it doesn't work.
Not sure if your coming at me or not.. But I could care less what people repeat, and we both know **** is repeated billions of times on here.... I put that out there, not cause I want to mindlessly state something doesnt work.. No, its because I had a really good friend with a sick PPW Z blow his engine with just his reflash ( flash- not sure if he confirmed it on a dyno ).. After that I had no more road dog.... Oh well right.....
Old Mar 4, 2008 | 04:03 PM
  #45
ChrisCJ99's Avatar
ChrisCJ99
Look what showed up today!!!
The Z gets dropped off this friday
Old Mar 4, 2008 | 05:26 PM
  #46
one350zfan's Avatar
one350zfan
Big dog? You mean "big tires"?
You should see the view from the back!
One day you'll get your chance!
Old Mar 4, 2008 | 07:20 PM
  #47
taurran's Avatar
taurran
Your point? I've seen numerous people blow their motors on UTEC and other EMS's with full tunes by well known shops. (Alberto and Jetpilot for instance)
It doesn't mean I'm going to run around and start preaching that the UTEC or these other piggybacks don't work.
Think about it...
Old Mar 7, 2008 | 12:41 PM
  #48
ChrisCJ99's Avatar
ChrisCJ99
Well, just drove about 400 miles on my new clutch within the past couple days.... Dropped the car off at the shop and overnighted the ECU to turbonetics Hopefully the car will be done by Wed. when I get back in town..... Hopefully there wont be any problems
Old Mar 7, 2008 | 01:44 PM
  #49
JonnyC's Avatar
JonnyC
Awesome! Let us know how it goes!
Old Mar 7, 2008 | 03:15 PM
  #50
Jay'Z's Avatar
Jay'Z
Think about it...
Ok.. Now your being stubborn.... I could say i have seen fully buuuuilt engines blown too.. etc etc...... So what then.. Dont get an engine build?????? Forget i said anything
Good luck with ur FI OP........
Old Mar 7, 2008 | 03:19 PM
  #51
taurran's Avatar
taurran
Really? You're saying that someone ran a Turbonetics kit on a built motor with low compression and still ran the reflash??? If they did, they deserved to have blown it. I also find it interesting because I haven't seen a built motor blow running a Turbonetics kit. That's most likely becaues people usualy go with a TT setup on a built motor. I'd like you to show me the instance and then show me how it's caused by the kit.
If you want to make comparisons though, I've seen more built motors blown on APS TT's than I have any other kit that I recall (Zivman, Julian, and marluci's old car that the other forum member bought). I've also seen many Greddy TT built setups blow headgaskets and other engine components. However, I'm not so naive to blame it on the turbo kit!
I'm not being stubborn at all, just saying that you're basing your ideas and information on knowledge that is incorrect.
Old Mar 7, 2008 | 03:41 PM
  #52
Jay'Z's Avatar
Jay'Z
I never baaaased the engines blown on any kit or ems...... I simply said UTEC w/ TN ST would be favorable............................................. Thats it Taurran........ Thats it.....................................
If the OP is going to go with only a flash...... Thats awesome........
Old Mar 13, 2008 | 03:24 PM
  #53
ChrisCJ99's Avatar
ChrisCJ99
Sooooooooooo. Turbo kit is on and the car and it SCREAMS!!!!! Running an open wastegate... And the final dyno #'s are...............
388 whp / 355 lb tq!!! More than what I was expecting! The car is just AMAZING!!!!! MY GOD I LOVE IT!!!!! But it's SOOOO SOOO freakin loud! I'm glad I replaced the clutch and put the new SS clutch line in as well. It feels WAY smoother and nice BIG BIG BIG ups to S&R in Tampa and Taylor and Mike especially. They did a SUPERB job on the install. SUPER SUPER clean, EXTRA wrapped everything and it looks just PERFECT. The car runs SO smooth now, IMO. it's everything I wanted it to be, and more I'll post pics and vids soon
Old Mar 13, 2008 | 03:36 PM
  #54
taurran's Avatar
taurran
Awesome! Those are some great numbers for an out of the box kit. Are you running the reflash still? See ya around.
Old Mar 13, 2008 | 03:41 PM
  #55
ChrisCJ99's Avatar
ChrisCJ99
Yeah, I'm running the flash for now. The techs say it runs great for an out-the-box flash. I'm lovin it right now Thanks for all your great input Taurran! I'll keep you posted
Old Mar 13, 2008 | 03:57 PM
  #56
JonnyC's Avatar
JonnyC
Congrats man! It's good to hear that everything went smooth!
Old Mar 13, 2008 | 06:09 PM
  #57
doug's Avatar
doug
if your kit is brand new.. here is some added security
https://my350z.com/forum/product-announcements/323286-turbonetics-now-offering-powertrain-warranties-for-all-kits.html
Old Mar 13, 2008 | 08:32 PM
  #58
Zivman's Avatar
Zivman
please don't generalize my name into this argument
Old Mar 14, 2008 | 05:01 AM
  #59
taurran's Avatar
taurran
That was a week ago. You'd like to continue it?
Old Mar 14, 2008 | 05:32 AM
  #60
NA&CH's Avatar
NA&CH
Congrats Chris. Enjoy the new power(that I dont know about ) and be safe
Chris
