Clutch Slip and vortech surpercharger
Old Mar 14, 2008 | 05:45 AM
james12345pt's Avatar
james12345pt
Default Clutch Slip and vortech surpercharger
Will clutch slip at high rpms decrease the amount of boost created by the supercharger? I just have my vortech installed by performance factory and seen to have a slipping stock clutch at ~6500+ rpm.
Old Mar 14, 2008 | 06:58 AM
DaveFunction2ND's Avatar
DaveFunction2ND
Most likely its belt slip. Clutch slip would most likely occur at peak Torque around 4000 - 4500. What pulley setup? What belt?
Old Mar 14, 2008 | 07:04 AM
james12345pt
Default vortech
I have an revup 06 with a 2.87 pulley with a gate belt from napa. I am not sure of the length. Would the small belt on the sc/ jackstand size slip as well. How tight should that belt be?
Old Mar 14, 2008 | 07:06 AM
MUZZY's Avatar
MUZZY
its belt slippage. my clutch is slipping at ~3500-4500rpm but if I down shift It dosnt slip from a 40mph most of the time.
Old Mar 14, 2008 | 08:30 AM
str8dum1's Avatar
str8dum1
what did they say at PF when they tuned it? Likely belt slip, but stock clutch wont hold all that extra power for long.
Old Mar 14, 2008 | 10:45 AM
booger's Avatar
booger
What is it doing that makes you think its the clutch ?
If a power loss is showing up on the dyno after 6500rpm , I would have to agree that its a belt slipage problem . Tighten up the belt and give it another try .
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
