APS TT Smoking again
Old Apr 9, 2008 | 12:48 PM
Chudson coupe's Avatar
Chudson coupe
How can that be true if he is only burning oil for 100 miles after his oil change? No matter what level of oil you are at (except for empty), you should be pushing oil through the turbo, and the problem would continue.
It seems like it would be constant if the issue was with the turbos themselves.
Old Apr 10, 2008 | 10:15 AM
noer's Avatar
noer
Originally Posted by Chudson coupe
How can that bet true if he is only burning oil for 100 miles after his oil change? No matter what level of oil you are at (except for empty), you should be pushing oil through the turbo, and the problem would continue.
Hi Guys thanks for the feedback,
Did some drifting with the car this weekend and now it seems fine... will get someone to drive behind me and check. I only drive the car weekends though... so I will check tomorrow or the following day and feedback. Will also check my oil level.
Cheers
Old Apr 13, 2008 | 05:52 AM
MR RIZK's Avatar
MR RIZK
not sure related but my HKS started to smoke on take off. Ended up being a pinched catch can line. Fixed that and the smoke went away
Old Apr 16, 2008 | 12:05 PM
noer's Avatar
noer
Cheers
It's actually still smoking.. but not as much as before but definately noticable. My oil level is on the L mark. How long does it take for oil to burn out of exhaust?
Old Apr 16, 2008 | 12:14 PM
Cannysage's Avatar
Cannysage
I'm only going to put 5qts from now on.. it's too easy to overfill. a lot of oil still get trapped in the tank, it seems like. once i got ****, and tilted one side much higher than the other and more came out, from when it was leveled.
Old Apr 16, 2008 | 12:22 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
5.5 quarts in mine and no oil consumption
Old Apr 16, 2008 | 12:47 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I put in 5 quarts on my Greddy set-up and it smoked like a chimney at start up, so embarassing! Now I run 4-4.5qts and keep it at medium to low with no issues. I bet your overfilling.
Old Apr 16, 2008 | 01:20 PM
Abishop's Avatar
Abishop
i know i already asked this but is the dipstick looks like this "H XXXXXX L"
Now is the full line for the APS TT kit the bottom of the hash on the L side (XXXX^ L) or the L itself (XXX ^L)? because there is about 1/8" gap between the two and that 1/8" could be why most people are smoking.
As a side note, is there a place that you can get parts for the APS kit? ie, a drivers side oil return line?
Old Apr 16, 2008 | 09:53 PM
Weqster's Avatar
Weqster
APS will parts individually. But for something like a simple oil return, u can get from most car part outlets. Im not familer with american stores, so i cant recommend.
Old Apr 17, 2008 | 05:04 AM
Julian@MRC's Avatar
Julian@MRC
We have seen 3 things commonly cause this issue..
1) to much oil
2) Oil returns need to be trimmed to straightest line possible
3) VERY dirty air filters..
Old Apr 18, 2008 | 06:10 PM
Abishop's Avatar
Abishop
Bump this question!
Old Apr 18, 2008 | 06:16 PM
Crom's Avatar
Crom
I keep mine at L...no smoking except when start up when its cold. As for parts...I'd try and fab something up from a local auto store....
Old Apr 18, 2008 | 08:35 PM
Abishop's Avatar
Abishop
Has anyone else had to make a oil return before? for an aps tt?
Old Apr 18, 2008 | 09:28 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by al_v
I always use my dipstick level exactly in the "L" or lower , never over the L. If I do that ,I have smoke.
same here
Old Apr 18, 2008 | 09:44 PM
weslutes's Avatar
weslutes
I bought some 45deg fittings with oil resistant hose & keep the oil level at the first X. So far no smoke, we'll see after the high boost tune next week.
Chris350z03
Oct 8, 2023 07:19 PM
bcoffee20
Nov 19, 2015 06:39 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
foxsmp26
Sep 25, 2015 09:48 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
