3.12 pulley removal
Old Apr 6, 2008 | 01:38 PM
05Z33's Avatar
05Z33
Default 3.12 pulley removal
How do I get this 3.33 pulley off? I've been useing this strap wrench and and a 14mm wrench and this dam thing will not budge. Would it be easier to remove after I install the mounting bracket?
Old Apr 6, 2008 | 01:41 PM
booger's Avatar
booger
Put the bracket in a vice and try that
Old Apr 6, 2008 | 01:52 PM
JET MECH's Avatar
JET MECH
you may want to try and use a heat gun on the pulley center shaft boss area. by heating it up just enough it will expand the aluminum to make removing the pulley easy.
Old Apr 6, 2008 | 02:06 PM
teh215's Avatar
teh215
Wouldn't a simple gear puller work?
Old Apr 6, 2008 | 02:22 PM
05Z33's Avatar
05Z33
I just got it off. I had to put a little more *** into it and it came loose. Thanks for the advise.
Old Apr 6, 2008 | 02:49 PM
teh215's Avatar
teh215
Crongrats. You should really post how you got the pulley off for those that search.
Old Apr 6, 2008 | 03:00 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
i had no issues with the strap wrench and socket with a breaker bar.
Old Apr 6, 2008 | 03:11 PM
05Z33's Avatar
05Z33
What I did was use the strap wrench on the pulley, and used a 14mm socket wrench on the bolt. I just squeezed them together towards each other and it came loose. You have to really muscle it for it to work. My next project is to polish the the intercooler. I just started on it yesterday and it is taking a long time. I might just take it to someone else to do it for me. If I get it done I'll post pics.
Old Apr 6, 2008 | 04:39 PM
str8dum1's Avatar
str8dum1
impact wrench
Old Apr 6, 2008 | 05:28 PM
Floridaboy1605's Avatar
Floridaboy1605
All you gotta do is put a wrench on the jackshaft bolt and a socket on serp pulley!!
Old Apr 6, 2008 | 06:09 PM
JonnyC's Avatar
JonnyC
I was going to say...I must have been lucky because I just put one wrench on the serp pulley bolt and one on the cog pulley bolt and the serp pulley bolt broke free.
Old Apr 7, 2008 | 06:50 AM
Floridaboy1605
Yeah its real easy why go through all the trouble with a belt wrench when you can just do that??? know what i mean?
Old Apr 7, 2008 | 06:53 AM
05Z33's Avatar
05Z33
Yea I tried that and it did not work. Maybe if it was mounted or in a vise things would have worked out differently. All that matter in the end is that I got it off.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Depravity
Oct 1, 2015 04:49 PM
