Where to Hook up Water temp GAuge??
Old Apr 10, 2008 | 04:02 PM
Floridaboy1605's Avatar
Floridaboy1605
Default Where to Hook up Water temp GAuge??
Hey guys, Since my last tune i wanted to add a oil temp and water temp gauge i was wondering where you guys placed to water temp sender??
Old Apr 10, 2008 | 06:14 PM
rrmedicx's Avatar
rrmedicx
I thought about buying a T adapter and running it on the driver side coolant hose that goes from the bottom of the radiator to the port in front of the temp thermostat.
Something like this:
http://cgi.ebay.com/ebaymotors/GREDD...spagenameZWDVW
Then just plug in the water temp sensor into the adapter...hook up your gauge and voila.
Not really sure if it matters terribly which side of the radiator, but I'm sure someone will chime in with the answer.
Let us know how you decide to go.
Old Apr 11, 2008 | 04:40 AM
jpc350z's Avatar
jpc350z
Wanna place the pick up at the inlet to the radiator. Coming from the engine it's the hottest the coolant temp will see.
Old Apr 11, 2008 | 04:45 AM
reptile718's Avatar
reptile718
Mine was installed on the main line toward the rear (passengers side), works very well.
Old Apr 11, 2008 | 04:47 AM
jpc350z's Avatar
jpc350z
Passenger side upper hose is the inlet to the RAD.
Old Apr 11, 2008 | 04:53 AM
rrmedicx's Avatar
rrmedicx
but which direction does the coolant flow? from the passenger (cold) side thru the engine and out the driver side (hot) to the radiator to get cooled? or vice versa? this is the only missing link. this would tell which side is hotter and where to place the sensor for the gauge..
Old Apr 11, 2008 | 05:02 AM
jpc350z's Avatar
jpc350z
If your standing in front of the car and looking into the engine , the top hose , passenger side is the return to the radiator from the engine.
Old Apr 11, 2008 | 05:13 AM
reptile718's Avatar
reptile718
Curious for those that have already done this what avg. temps are you guys seeing?
Old Apr 11, 2008 | 05:14 AM
Zivman's Avatar
Zivman
that is where I placed mine. split the hose, put in the adapter and installed the sensor. Pretty straight forward
Old Apr 11, 2008 | 05:19 AM
JasonZ-YA's Avatar
JasonZ-YA
I HAVE THAT exact same one... just havent gotten around to installing it....
maybe this weekend i can find the time..
- j
Old Apr 11, 2008 | 08:37 AM
alan21's Avatar
alan21
^^ i have a sleeved engine with lots of cooling mods (koyo r spec, gtm fans/shroud, pathfinder cooling mod, and a bottle of water wetter for good measure lol )and on average see temps of about 90 degrees celcius not sure if that helps
Old Apr 11, 2008 | 09:40 AM
jpc350z's Avatar
jpc350z
About 185 F during cruise and 200-205F in traffic..
Old Apr 11, 2008 | 10:07 AM
reptile718's Avatar
reptile718
Mine are about 140-150 F during cruise and 180-185 F in traffic. Only cooling mod I have is a Nismo thermostat and cap.
Old Apr 11, 2008 | 11:20 AM
MIAPLAYA's Avatar
MIAPLAYA
You could use a Blitz coolant hose which has a port built for this.
Old Apr 11, 2008 | 12:02 PM
Floridaboy1605
where can u purchase those!!
Old Apr 11, 2008 | 12:54 PM
gothchick's Avatar
gothchick
+1
That's where mine is.
Old Apr 14, 2008 | 07:20 AM
MIAPLAYA's Avatar
MIAPLAYA
I got mine here:
http://www.hopupracing.com/blcopeni35.html
But I'm sure other vendors carry it as well..
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
