Random pictures from powerlabs turbo install
Old Apr 13, 2008 | 08:06 PM
jeffie7's Avatar
jeffie7
I got an AIM from a random person asking, hey are you the person having issues with the powerlabs directions? yeah? well I write them. =)
He answered a bunch of questions and cleared up a lot of stuff. No doubt some things were missed in the directions, anyone who buys the kit in the future should have updated directions.
anywho.
some more pictures.
FYI Band clamp on the cross over to the first up pipe is 2.5" not 3"
up pipe 2, goes up the side of the A/C compressor.
top view
A/C line #2, not noted in the directions, I figured it followed the factory one.
couldn't fit this one in the rubber grommet. I might wrap it or mod the grommet so it wont get cut over time.
3" down pipe, will it fit? sure as hell doesn't seem like it. but if done just right, yes, yes it does fit!
yay it fit!
will finish up the turbo tomorrow
Crash bar mounts, you must cut them to fit the massive I/C
front before moving things around.
After relocating the air bag sensor, flipping a horn around and cutting the other horns mounting bracket, I was able to make them all fit, oh I also had to move the ground wires around for the horns. just loosen the 8mm nut and turn the wire. easy enough.
FYI I wanted to bend the factory bracket for the air bag sensor so it was flat, after bending it and making all the paint flake off the bracket I noticed that the I/C still wouldn't clear the bottom of the sensor where the clip is. so I ditched the idea and moved it to where the horn is mounted.
Called it quits for the day and went inside to Linh cutting up some fresh fruit.
straw berries, white mango, and water melon. yum
Outside of not understanding the directions, I'm finding this install to be over all... very easy. I have enough tools that I can easily make things work the way I want them to work, thanks to that 45o elbow socket (not sure what its called) That has been my go to tool, as with some ratchet style wrenches.
I have about a full day into it now, I started yesterday around 4pm-8 and today I worked from around 2 to 11 taking many breaks the whole day and getting side tracked with other things outside of the turbo kit.
Whats left to do.
Turbo install should take some time
oil spacer/oil lines should be easy.
charge pipes/BOV shouldn't be bad
exhaust/waste gate should be very easy
utec, once I figure out how to load a map, it will be easy.
once thats done, I need to run my return fuel lines, install my boost controller, and install my gauges.
fun fun fun.
it's going much much much faster then I thought it would. thats for sure!
Old Apr 13, 2008 | 08:10 PM
IIQuickSilverII's Avatar
IIQuickSilverII
oh dammm!!!!
THATS BAD *** JEFF!!!!!!!!!!!! major progress today
Old Apr 13, 2008 | 08:12 PM
diwun67's Avatar
diwun67
Good job man, that IC is MASSIVE!
Old Apr 13, 2008 | 08:15 PM
jeffie7's Avatar
jeffie7
oh dammm!!!!
Not bad since I slept in, played with the kitten, got online, looked at ****, ate lunch, talked bs with my neighbor about motorcycles, worked on my body kit, jacked it up, then got started. =) If I work up early and jumped on it, it would no doubt be done.
Old Apr 13, 2008 | 08:19 PM
IIQuickSilverII
and lets you keep 'full" crashbar
tnk210's Avatar
tnk210
LOL @ the extensions, I did the same thing
This was mine
Attached Thumbnails Random pictures from powerlabs turbo install-photo-6-.jpg
Old Apr 13, 2008 | 08:21 PM
plumpzz's Avatar
plumpzz
Those poor socks. I think once you get started on an install, its easy. Good luck!
Catchmeifyoucan's Avatar
Catchmeifyoucan
jeffie7,
Linh looks very familiar. Did she used to live in O.C?
Old Apr 13, 2008 | 08:25 PM
jeffie7's Avatar
jeffie7
Originally Posted by Catchmeifyoucan
jeffie7,
O.C as in Ocean City Maryland, or O.C as in Orange County.
no to both, but from what I understand there's veit chicks all over orange county
Nexx's Avatar
Nexx
this thread should shoot down all rumors that jeffie is only a two trick pony, keyboard and cooking. nice work jeffie, i cant wait to see the finished product!
Old Apr 13, 2008 | 08:58 PM
jeffie7's Avatar
jeffie7
you'd be surprised at some of the things I've done over the years. =)
Old Apr 14, 2008 | 03:26 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I am sure you have given this all some thought but I would suggest installing your vaccuum/boost and control lines cuncurrently. Which includes the all those BOV, wastegate, and utec map sensor lines.
I didn't consider this before I started my install and I ended up with a snake nest of death.
Old Apr 14, 2008 | 03:33 AM
taurran's Avatar
taurran
That 4-bolt flange on the turbine outlet brings back nightmares. V-band is mucho easier.
I'm assuming that's why they leave the turbine housing off, becuase it's impossible to tighten those bolts on the flange without doing it. Just be extremely careful when putting the turbine wheel in the housing, it's really easy to do some damage if not careful.
Old Apr 14, 2008 | 05:43 AM
ct350z's Avatar
ct350z
good luck with the kit jeffie, glad to see another DNF'r repping a badass z!!!
Old Apr 14, 2008 | 05:50 AM
JETPILOT's Avatar
JETPILOT
Very nice Jeffie... that's no small task installing a turbo kit yourself. Subsrcibing for the results.
JET
Old Apr 14, 2008 | 06:02 AM
UMW350Z's Avatar
UMW350Z
Looks good man! I would not be able to do all of that. As Ali G would say...RESPECT!
Old Apr 14, 2008 | 06:17 AM
DanielW's Avatar
DanielW
subscribed...
Old Apr 14, 2008 | 07:51 AM
  #38
Philthy's Avatar
Philthy
Boost Junkie
very nice and good luck!
Old Apr 14, 2008 | 09:53 AM
  #39
Old School's Avatar
Old School
Shift_Boost
Looking good Jeffie....Yet another boost'd DNF member! woo hoo!
Old Apr 14, 2008 | 09:56 AM
  #40
G3po's Avatar
G3po
Good pics.
Curious about the up-pipe , WRT the pipe with V-band underneath and the four bolt flange (up-inlet to the housing).
Does it appear possible to bolt the housing to that pipe "first" and then snake the up-pipe down to the bottom, (attaching the v-band last)?
Those bottom four bolts look pretty nasty to get to as well that the down pipe flange.
