what BOV are people running on there procharger
Old Apr 15, 2008 | 10:10 AM
frankie945's Avatar
frankie945
Default what BOV are people running on there procharger
just wanted to know what bypass valves people have on there procharger setups. And the easiest to mount in the original location were the proflow bov is.
Old Apr 18, 2008 | 12:00 PM
frankie945's Avatar
frankie945
There has to be some procharger guys out there. I need some input and sure other would like to know also.
Old Apr 27, 2008 | 11:11 AM
JRYAN350Z's Avatar
JRYAN350Z
you dont run a BOV with a procharger. BOV (blow off valve are used in f.i turbo set ups.) prob why you cant find your answer
Old Apr 27, 2008 | 11:18 AM
SC 350Z's Avatar
SC 350Z
hey i used a rs type blow off valve on my procharger setup the spring is a little to tight so you have to cut a little bit off of it or like before i got the blow off is un plug the recirculator hose on your intake plug off the hole on your intake and let it go into the atmoshpeer it sounds just like a hks ssq or i have seen hks ssq's on a couple of prochargers
Old Apr 27, 2008 | 11:19 AM
SC 350Z's Avatar
SC 350Z
you can run a blow off vale on a supercharger kit i know you can on the procharger im sure you can with the vortech and i have seen and heard of people doing it i was one of them so no it isnt just for turbo setups search a lil bit and youll see that you can do it
Old Apr 27, 2008 | 11:25 AM
eltness350's Avatar
eltness350
The Untouchable
heres a greddy type rs on procharger..when i had it...
http://s70.photobucket.com/albums/i1...ent=myz002.flv
Old Apr 29, 2008 | 05:32 AM
frankie945's Avatar
frankie945
look in the title it says bypass valve, Duh...
Old May 15, 2008 | 02:01 PM
itpro2002's Avatar
itpro2002
Hks
Old May 15, 2008 | 02:03 PM
frankie945's Avatar
frankie945
Originally Posted by itpro2002
Hks
how much boost are you running?
35reilly
Sep 28, 2015 07:42 AM
