Coolant Coming out around Oil Filter
Old Apr 19, 2008 | 12:33 PM
iconZ33's Avatar
iconZ33
Default Coolant Coming out around Oil Filter
Look guys i went to purge my radiator and change my oil today did both installed oil filter back on now when i start my car coolant is running out next to oil filter? Anybody know what is going on?
Help Thanks in Advance
Pictures show where oil filter goes and if ya look to the left is there suppose to be a pin hole right there..
Attached Thumbnails Coolant Coming out around Oil Filter-picture-001.jpg   Coolant Coming out around Oil Filter-picture-002.jpg
Old Apr 19, 2008 | 12:39 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Our cars come equipped with a oil cooler/warmer, which is located where your oil filter is installed. Hopefully one of those lines are leaking, or the adapter itself.
If the coolant was in your oil, you would be able to tell right away, unless your running the Evans NPG.
-George
GTM
Old Apr 19, 2008 | 01:18 PM
iconZ33's Avatar
iconZ33
well on the 2 pictures to the left in the middle there is a little pin hole where it is coming through is that suppose to be there
Old Apr 19, 2008 | 02:25 PM
iconZ33's Avatar
iconZ33
Well looks like it a pin hole is there anyway i could get this bypassed or something i could seal the pin hole with????
Old Apr 19, 2008 | 03:00 PM
iconZ33's Avatar
iconZ33
Would it be ok to bypass my Oil cooler by connecting the 2 lines and capin the ends to the oil cooler...
thanks in Advance
Old Apr 19, 2008 | 04:10 PM
GTM's Avatar
GTM
thanks in Advance
The OEM cooler has 2 purposes, One is to heat up your oil to proper operating temps with the coolant, and second to keep it cool once operating temps have been met.
If you bypass it, and add an external oil cooler I guess that would be ok, but, you still would not be warming up the oil as quickly as it used to. So its a trade off.
Old Apr 19, 2008 | 05:35 PM
fklentz's Avatar
fklentz
I looked at the exploded diagram in the service manual CD, I don't see any reference to the weep hole but I'm sure it's there for a reason. If it were me I'd just pull the oil cooler out and look at it, or replace it. The cooling water lines can just be pinched to hold the cooling water remove filter then the threaded part that the filter screws onto unscrews from the lower pan and releases the oil cooler.
There is an o-ring in there that seals oil in so if it were me I'd have a new cooler and o-ring in hand prior to starting. I think you may have damaged the cooler by over tightening the oil filter.
Good luck, looks like an easy fix...
Old Apr 19, 2008 | 05:59 PM
iconZ33's Avatar
iconZ33
Thanks guys will be ordering a new one
Old Apr 19, 2008 | 06:22 PM
fklentz's Avatar
fklentz
I looked the cooler up from nissan it's 252 bucks, at that price I think I'd just look at an after market cooler.
Old Apr 20, 2008 | 05:26 AM
iconZ33's Avatar
iconZ33
Thanks Guys will be looking at a aftermarket cooler... any suggestions?
Old Apr 20, 2008 | 09:43 AM
QuadCam's Avatar
QuadCam
thanks in Advance
it will be fine. that cooler doesn't have enough capacity to really cool the oil down. It's main purpose is to help get the oil up to operating temps as fast as possible as this reduces emissions and that is of the utmost priority for OEMs.
there has been debate over the usefullness of the stock oil warmer/cooler...I think Nissan pretty much ended the debate when they eliminated it on the HR version of the VQ. The HR does not have it. So, I fell safe in telling you that its okay to bypass/remove it from you car.
I removed mine and have had no troubles.
Old Apr 20, 2008 | 09:57 AM
GTM's Avatar
GTM
With a $250 price tag, I would most likely remove it and run an external cooler as well...
Old Apr 26, 2008 | 07:19 PM
z350boy's Avatar
z350boy
The CHEAPEST oil cooler set-up i sgoing to cost you MORE than the dealer price....BELIEVE ME!!!!
Old Apr 27, 2008 | 03:30 PM
fklentz's Avatar
fklentz
True, My point is that with the cost of the OEM cooler it would be just as well to spend the extra money for a higher capacity oil cooling system.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
