Eagletanggreen---->*Ikeya seqential Shifter Video*<------ Finally!
Old Apr 20, 2008 | 12:53 PM
  #61
phunk's Avatar
phunk
CJ Motorsports
nice vid, thanks for that!
Joe isnt too far from me, maybe ill hike out there some day to check it out. im a little broke for it right now, but maybe later this year.
Old Apr 20, 2008 | 01:11 PM
  #62
baspence's Avatar
baspence
am I just failing or did you take the 2nd vid off? I don't see it anywhere.....
Old Apr 20, 2008 | 01:15 PM
  #63
XKR's Avatar
XKR
baspence = Fail...
Its still there.
Old Apr 20, 2008 | 01:47 PM
  #64
baspence's Avatar
baspence
lol, Dayum.... alright.....
Old Apr 20, 2008 | 01:48 PM
  #65
baspence's Avatar
baspence
**** man, I was looking under photobucket not the youtube
Old Apr 20, 2008 | 02:57 PM
  #66
turismo's Avatar
turismo
Originally Posted by JAMEZ@CiNcity
Wat?
Props to Joe for figuring that out in that case.
Old Apr 20, 2008 | 04:52 PM
  #67
MADScientist's Avatar
MADScientist
Not sure if someone already answered this, but now that Joe has done a couple of these, what's the approximate installation time?
The biggest determining factor is if you have solid motor mounts or not. Luie did and we had to drop the transmission on his car to get to the top so I could install the shims and remove the OEM shift arm. He did not have a greddy kit so it took about 4-5 hours total install time. Greddy kit would mean taking off the wastegates... so add another 2 hours for that.
You are supposed to be able to install this by just unbolting the tranny mounts and let the engine sag down. This should shave 2 hours off the install time by not having to drop the transmission.
Then it just depends on where you want to mount the shift indicator. We put Luie's in the gauge cluster, that took about 1.5 hours to fit it in there.
So... it could take as little as 3 hours up to 8 hours depending on what parts you already have installed on the car.
Old Apr 20, 2008 | 05:47 PM
  #68
JAM3Z's Avatar
JAM3Z
Phenom
^Very good info. I'm anxious to see this thing in action at ZDayZ
Old Apr 21, 2008 | 05:33 PM
  #69
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Thanks, theres always CC J/K.
If you listen closely you can hear your pumps!
Old Apr 21, 2008 | 05:51 PM
  #70
SirSpeedyZ's Avatar
SirSpeedyZ
pretty sweet, its so tall though
Old Apr 21, 2008 | 06:33 PM
  #71
Motormouth's Avatar
Motormouth
Jkenefic:
I thought you had also opened up the transmission to adjust some things to make it shift smoother and work properly. this comes from a different thread where I thought this was mentioned.
do you not need to open up the transmission?
Old Apr 21, 2008 | 06:37 PM
  #72
brickyardgreg's Avatar
brickyardgreg
very cool thread and great vid. i think you answered every question i ever had on driving a sequential shift. well done and of course your car is insane.
enjoy
Old Apr 21, 2008 | 06:58 PM
  #73
MADScientist
Originally Posted by Motormouth
Jkenefic:
There are some springs and shims that get changed/added to the tranny as well as a shift lock out that gets removed... So yes you do need to open up the tranny, but not like you would think. just some access covers and bolts.
All of that is included in the kit and is detailed in the instructions.
Old Apr 22, 2008 | 03:01 AM
  #74
S12 driver's Avatar
S12 driver
Very cool mod. Just curious though, after this conversion, can you upshift without using clutch? On some of the Ikeya video they showed them upshift without touching the clutch at all. Is that possible for the Z's transmission?
Old Apr 22, 2008 | 03:07 AM
  #75
MADScientist
You can do it, but I would not recommend that if you want you syncros to last.
Those Ikeya cars are running dog boxes that are not using the clutch. I am working with PPG gears for a gearset that will swap into our transmissions but the cost is quite high unless we can get a run of 20 or more.
Old Apr 22, 2008 | 04:00 AM
  #76
3.6z's Avatar
3.6z
Worthless with the clutch setup. i was interested in this at the begining, but sincethen... looks the same thing as the origional 6sp. $1600 worth a new tranny..
Nice vid
Good Luck
Old Apr 22, 2008 | 05:51 AM
  #77
Motormouth's Avatar
Motormouth
I always wondered how you downshifted with a dog box. upshifts need to be done at full throttle application, right? so part throttle downshifts or what? rev matching is probably necessary.
Old Apr 22, 2008 | 09:32 AM
  #78
eagletanggreen
Got Track!!!!!
Nice vid
Good Luck
Thanks for your input, and your right $1600 can buy you and nice used tranny. If only Dog gears were a more affordable??
Old Apr 22, 2008 | 10:17 AM
  #79
KempieZ's Avatar
KempieZ
I also looked into the PPG gearboxes and they are pretty expensive. It will cost a little fortune for a good gearbox that can hold all the power you throw at it. Now going to build mine, dogbox. Still a bit affordable.
Old Apr 22, 2008 | 02:19 PM
  #80
garage-c's Avatar
garage-c
Seriously... Get some sub belts, tighten them after you tighten your lap belt, THEN tighten your shoulder belts. You are going to slip out the bottom of that harness with how high you wear that lap belt.
