TURBONETICS and smoking????
Old May 7, 2008 | 08:01 PM
carfi179's Avatar
carfi179
Originally Posted by JETPILOT
I don't think the oil pan spacer return is the issue. As long as the turbo is above the lowest point of return the oil will enter the pan even if the return is below the oil level.
What I would like to know is what your AFR was when you dyno'd the car and what your maximum boost is on your gauge. I think another compression test is in order here. If the tuebo seal was blown (which happens over time) then you would only have blue smoke comming off WOT. Sounds like you blew your motor.
JET
+1 on this comment.
BTW: I have the AAM oil return line and spacer for the same reason you have, no blue smoke...
Old May 7, 2008 | 10:35 PM
SpoilsofWar's Avatar
SpoilsofWar
Spacer is not the issue, there are lots of people including me who are running them on the TN kit without issues. It may be your return line routing, but the spacer itself will not cause oil backup and blown turbo seals...
What degree fitting are you using from the return line into the spacer? Straight, 45 degree or 90 degree?
Personally, I would start looking for other culprits.
Old May 8, 2008 | 03:25 AM
taurran's Avatar
taurran
I think it's the return line being kinked or possibly a pcv issue, not the spacer.
As far as the fitting on the return line, I personally don't think it matters as long as the rest of the return is downhill and not kinked.
Old May 8, 2008 | 07:50 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Another thing I just noticed after reading your original post is the kit is new. If the kit is brand spanking new it is normal to see or smell smoke on a new kit due to the glue and piping getting hot for a fews days. After a while it will go away so if that is the case wait it out. Other than that make sure there is no 90 degree turns or kinks on the drain lines. Also DO NOT use 90 degree fitting on the drain.
Old May 8, 2008 | 09:01 AM
SC 350Z's Avatar
SC 350Z
got to the garage last nite put the car back up on the lift looked and checked the oil return line no kinks and or smashed hose, made sure the line was at a downward slop and that it never went below the return hole,lowerd the car back down, took the upper charge pipe off and this is what i found,
[IMG][/IMG] this is the pcv line that was pinched on the drivers side, so i took the old hose the kit told you to take off put it back on took a 5/8 barded conncetor and hooked it up that way and it works fine now, when the kit was installed my buddy had done this part no biggie though, so from what i get since this was blocked the block was being pressurized am i right?
Old May 8, 2008 | 09:10 AM
350 Rookie's Avatar
350 Rookie
ooof. kink ftl
Old May 8, 2008 | 11:23 AM
SC 350Z's Avatar
SC 350Z
ran it today and to work and it runs great havent hit boost to much but it dont smoke taking it to AAM to get it further tuned in june.
Old May 8, 2008 | 11:30 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Good to hear it was an easy fix.Its weird how the littlest things can screw something up.
Old May 8, 2008 | 11:32 AM
SC 350Z's Avatar
SC 350Z
i know tell me bout it when i seen it i stepped back and opened up a beer lol
Old May 8, 2008 | 12:45 PM
taurran's Avatar
taurran
Nice. I like it when it's an easy fix like that.
Old May 8, 2008 | 01:25 PM
SC 350Z's Avatar
SC 350Z
yea me to it has stopped smoking pretty much it just smells like somin nasty still though
Old May 9, 2008 | 10:33 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Normal for a new kits remember new pipes and such but give it some time. You may even see a small amount of smoke. Did you get the kits with or without the cats? Also glad you found your fix so now go back to happy boosting.
Old May 9, 2008 | 11:27 AM
SC 350Z's Avatar
SC 350Z
w/o cats and its getting dropped of to be tuned on monday
Chris350z03
Oct 8, 2023 07:19 PM
allmycarsdie
May 13, 2016 04:38 PM
Juztin
Nov 22, 2015 07:03 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
smithmt3
Sep 11, 2015 08:25 PM
