Utec Map for ATI Procharger?
Old May 7, 2008 | 05:32 PM
Heath's Avatar
Heath
Default Utec Map for ATI Procharger?
Does anyone have a map for the Utec for an ATI Procharger?
I need one for the inline fuel pump and fmu...
and/or one with 440cc injectors and upgraded fuel pump..
doing an install this weekend and want to get a Utec, but tuning is $450... just running out of money
figured that is what forums are all about
I've found maps all over the web for every kit but this one
Old May 7, 2008 | 08:44 PM
eltness350's Avatar
eltness350
The Untouchable
i used the tn st map when i first got my car running...just dont go into boost till the tuner gets a hold of it...and i drove 3hrs with it/stock block no problem...
Old May 7, 2008 | 10:55 PM
Heath's Avatar
Heath
you used the TN map just to get it over to the tuner?
the problem is I just don't want to pay $450 for a tune
was hoping someone would have a 7psi stock kit/block map
or even a 7 or 9 psi with injectors/walbro map...
Old May 7, 2008 | 11:05 PM
DJShan209's Avatar
DJShan209
you should really hold off for a while and go with a tune.
best way imo especially if you wanna do it right.
spend $450 to get a good tune instead of a going broke
when you blow your engine w/ a crappy one.
Old May 8, 2008 | 03:05 AM
350Z400rwhp's Avatar
350Z400rwhp
+1 This is more important then everything! You must get the proper tune for your car.
Old May 8, 2008 | 07:47 AM
Heath's Avatar
Heath
I'm learning to tune it myself I think, was just hoping someone had a good base map...
thanks everyone
Old May 8, 2008 | 10:53 AM
str8dum1's Avatar
str8dum1
then that TN is a good basemap to play off of.
without a dyno it will be tough to get the timing right
Old May 8, 2008 | 11:18 AM
eltness350's Avatar
eltness350
The Untouchable
+1 and 450 for a tune seems high....search a bit usually its like 250 with the wideband....
Old May 8, 2008 | 11:24 AM
JonnyC's Avatar
JonnyC
i'm going to use the TN base timing map for my vortech setup, until I can get it on a dyno. Luckily my used kit came with a fuel map for the 650cc's, which will be a good starting point.
Old May 15, 2008 | 01:46 PM
itpro2002's Avatar
itpro2002
no one in these forums will share that info I tried in another thread and got nothing but grief and all I wanted to do is compare the different ones to learn a little about tuning. But these guys will not share the info
Old May 15, 2008 | 03:53 PM
str8dum1's Avatar
str8dum1
i think of people were tuning the cars themselves, like they do in the subaru forums, then people would be more open.
realistically, those TN maps are a great starting point. but without a dyno, its all guess work. The shops have done so many setups, they just know what #;s to start with and then use the dyno to fine tune it. Dont expect to street tune to that level.
Old May 15, 2008 | 04:00 PM
JonnyC's Avatar
JonnyC
Most people don't bother tuning themselves and go straight to a shop. I planned on doing everything myself, but I realized that I'll need to go to a tuner at some point. After that, I won't feel right about sharing the map publicly, because that just wouldn't be right.
Old May 15, 2008 | 04:02 PM
jeffie7's Avatar
jeffie7
I paid more then 500 for my utec tune.
450 doesn't sound too far out unless they're doing the tune in car with no dyno.
Old May 15, 2008 | 04:04 PM
SpoilsofWar's Avatar
SpoilsofWar
Wouldn't be right? Screw that... The way I look at it, I paid for the tune, I now own the map. I didn't sign any fcking confidentiality agreement with my tuner...
itpro2002, dude if you want my UTEC 8psi turbonetics tune I will pm it to you when I get back home in a week. And I would be more then happy to share it, and all my subsequent maps when they're done, with the rest of the forum as well.
Old May 15, 2008 | 04:10 PM
JonnyC's Avatar
JonnyC
Ehh..maybe you're right.
Old May 15, 2008 | 05:08 PM
itpro2002's Avatar
itpro2002
Right on guys I am going to post mine when it is done. Im not shy and this is suppose to be a community I don't care how much I pay. You guys that don't feel right must not download music or program and movies ya right lol.
Old May 15, 2008 | 05:09 PM
itpro2002's Avatar
itpro2002
map would be awsome thanks spoils
Old May 15, 2008 | 07:13 PM
Heath's Avatar
Heath
I have an appointment Monday at 3pm.
it'll be with what's in my sig
I'll post it up.
I may even try a 7lb on one map then a 9lb on another in which case I'll post both, but not sure will be time
I completely agree with sharing maps.
Look at myself, my car is done, but I can't drive it all weekend because I dont have a safe map at the least, so it has to sit and wait till tuned
Old May 15, 2008 | 07:14 PM
Heath's Avatar
Heath
and I don't have my spray bar yet, so i won't be spraying
Old May 15, 2008 | 08:29 PM
jeffie7's Avatar
jeffie7
Last thing I would do is run anyone elses map, at least on my boosted car.
It's one thing to run it for a base map to get you to and from your tuner, but if you plan on making any real boost on it...
Don't even try. you might as well trust a ECU reflash.
