Quick Vortech install Question???
Old May 7, 2008 | 06:11 PM
turtle1678's Avatar
turtle1678
Default Quick Vortech install Question???
Can someone clarify something for me? Im in the process of installing my kit and I have the fmu together and the pump together but my question is this....
there is a vac line that attaches on the front of the FMU that you connect a 5/32 hose to does that then tee into the BPV and then up to a tee in the ss box and then into the manifold? And for the vent hose is that just open facing the ground??
Thanks Guys
Old May 7, 2008 | 06:51 PM
booger's Avatar
booger
Yes ...you can connect all the vacuum hoses with T fittings and then up to the plenum . The vent hose coming off the vlave cover should be ran back to the intake air filter an the blower
Old May 7, 2008 | 08:28 PM
turtle1678's Avatar
turtle1678
thanks for the help really appreciate it
Old May 8, 2008 | 04:35 AM
eez's Avatar
eez
i think he meant the vent hose on the FMU. I was never able to keep the vent hose connected to the little nub on the FMU, so good luck with that. Either way it's just a small hose that vents towards the ground so water doesn't get in it.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
TrackFiddy
Sep 24, 2015 11:40 PM
NYGiants0186
Sep 8, 2015 10:37 AM
