0w 40 Oil? Help
Old May 14, 2008 | 10:07 AM
thawk408's Avatar
thawk408
Originally Posted by jpc350z
Where can you find it and what does it cost? What filter recommended?
I got it from Walmart for $16/gallon. I just use the factory nissan filter.
Old May 14, 2008 | 10:47 AM
jonnylaw's Avatar
jonnylaw
oem oil filters are sh*t. I buy my ow40 from pepboys, and get a free mobil1 filter.
Old May 14, 2008 | 11:08 AM
pimpsahab's Avatar
pimpsahab
I use AMSOIL 10W-40 with a Mobil 1 Oil filter and its running smoothly
Old May 14, 2008 | 11:58 AM
athenG's Avatar
athenG
Do you mean **** in a good way or bad? I cant remember but this has been discussed here and the OEM Oil Filter is more than enough even with built motor. If I'm not mistaken majority of guys here use the OEM filter.
Edit:
It is a sticky..lol check this thread.. OEM FTW https://my350z.com/forum/forced-induction/323131-built-motors-what-oil-filter-are-you-using.html
Old May 14, 2008 | 12:26 PM
thawk408's Avatar
thawk408
The OEM filter is fine.
Old May 14, 2008 | 12:30 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
+1 oem filter is great!
Thawk you going to Z days??
Old May 14, 2008 | 12:32 PM
thawk408's Avatar
thawk408
I might be there some saturday, if I can sneak away from this damn wedding!
Old May 14, 2008 | 12:34 PM
eagletanggreen
Got Track!!!!!
FAIL!
Old May 15, 2008 | 05:46 AM
jpc350z's Avatar
jpc350z
If it's yours good idea..
Old May 15, 2008 | 05:59 AM
QuadCam's Avatar
QuadCam
Originally Posted by Jeff92se
QuadCam. Isn't that an oil engineered for turbo diesels? Where is that available?
It is engineered for turbo diesels.....and gas engines, too. It is not strictly a turbo diesel oil. It is a great oil.
Old May 15, 2008 | 06:06 AM
QuadCam's Avatar
QuadCam
AutoZone and Walmart both carry it. It is inexpensive....something like $16 per GALLON! or maybe even less. I can't remember. It comes in the blue container.
Old May 15, 2008 | 07:21 AM
thawk408's Avatar
thawk408
No its not mine....thank god!
Old May 15, 2008 | 07:31 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by Nexx
m1 0w40 all the way. enjoy.
Werd. That's what I run too. I run the $hit out of my car sometimes too. No problems what so ever. BTW, to the OP, I live in a similar climate as you. Houston, Tx.
Old May 15, 2008 | 07:39 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by aguita
Hello..
I dont understand the oil sticky here..so my question is..
Im superchagerd and going to change the oil this week..
Stock Block ,stock internals
Previous owner told me that he always used 10w-30 Mobil1
after reading a couple of thread some ppl recommend the 0w-40 euro car formula..
So Which Oil should i pick up??
My temp is sometimes @ night 24 C (74 F) and in the day 30-35 C (86 + F)
I drive sometimes my car pretty hard..and i saw on a thread that the 10w 30 can get to thin when you drive hard..
So What should i stick to??
thanks
Read the following thread. Start with post #94. I had the same questions you have about the oil. It should clear up things for you.
https://my350z.com/forum/engine-and-drivetrain/290440-project-arc-engine-bay-build-in-progress-5.html
Old May 15, 2008 | 09:37 AM
Jeff92se's Avatar
Jeff92se
Thanks. I normally use a 30wt wether it was a Mobil 1 5w30 or Penzoil plat. I just got two 5 qt jugs of PP to try. Now I want to give Rotella a try!
Do you happen to know if the Rotella synthetic 40 weight has a viscosity closer to a typical 30w?
Old May 15, 2008 | 09:44 AM
j.arnaldo's Avatar
j.arnaldo
My Owner's Manual specifies 5W30. My personal pick is Mobil 1 (a good combination of quality & price); when it's on sale, I stock up--'bout twice a year. I gather, any brand that's got the "SAE/API" on it, has got to be good!
Old May 15, 2008 | 11:20 AM
aguita's Avatar
aguita
vo Thanks for your help...i guess we live in the same climate...im going to pick up the 0w40.. 11 Dollars per quart @ my local parts center..it says eurpean car formula fully syntethic...so did you figure out what was the cause of the sound on your car??
Old May 15, 2008 | 11:23 AM
  #38
Nexx's Avatar
Nexx
wtf?? $11.00? should be about $6.00 per. and yes it should say european car formula on it.
Old May 15, 2008 | 11:30 AM
  #39
Resolute's Avatar
Resolute
Not even close. It's a solid 40 weight, unlike the relatively thin M1 0w-40 grade.
WTF?!! Who is selling you this oil? Last time I looked it was around 6 dollars at Wal-Mart. Even NAPA is cheaper than that.
I originally recommended the Rotella T-Syn for QuadCam and some other guys running forced induction. The oil is well designed for this use, and has a good history of excellent UOA's from a variety of turbo engines, both gasoline and diesel. I am now running it in my car just to see how it does in a NA engine, and will post my own results whenever I get around to changing the oil. Probably in the next week.
Will
Old May 15, 2008 | 12:09 PM
  #40
VO...'s Avatar
VO...
Administrator
Will
Listen to this guy. He's know what he's talking about.
+1 on WTF with $11/quart
