2.87 pulley.... not sure... but...
Old May 19, 2008 | 11:14 AM
Hexxum001's Avatar
Hexxum001
That doesn't seem right at all. Running rich with the 2.87 pulley with the stock fuel system?? Either his Z is one in a million or his afr readings are off. You can take the chance if you want, but I wouldn't recommend it at all. You are asking for BIG problems running the 2.87 with the stock fuel system.
Old May 19, 2008 | 11:45 AM
JET MECH's Avatar
JET MECH
go for it! tune the 2.87 on the stock injectors/fuel system, i would like to see the outcome. it's not my engine so i could give a **** less what happens.
Old May 19, 2008 | 11:59 AM
sentry65's Avatar
sentry65
the burninator
how's the injector duty cycle and fuel pressure with the stock injectors and 2.87 pulley?
maybe you get enough fuel, maybe you don't. But if your fuel pressure is insanely high and your injectors beyond maxed out, it doesn't matter because you'll still be looking at buying a new engine soon enough
Old May 19, 2008 | 12:18 PM
nomyth46's Avatar
nomyth46
how much boost does a 2.87 pulley make?
Old May 19, 2008 | 12:50 PM
sentry65's Avatar
sentry65
the burninator
anywhere from 6-26 lbs depending on the
- engine rpms
- blower type
- intake manifold
- intake tube diameter
- displacement
- heads
- cams
- headers
- cats/pipes
- exhaust
- ambient temp
- altitude
etc etc
though more psi doesn't necessarily mean more power, it just means there's more restriction in relation to the airflow going through the engine
Old May 19, 2008 | 01:13 PM
booger's Avatar
booger
The stock Vortech fuel system is a rising rate of [ 8 to 1 ] on older models and [ 6 to 1 ] on the newr years . The 2.87 pulley is going to get you around 3-4psi more boost than the stock pulley . Thats 18 to 32 psi higher fuel preasure for short periods of time . Is it a good thing ? NO ! But you guys way overreact like a bunch a freaked out women . If the guys car is able to get to redline with out getting lean . It isnt going to blow up [ as long as he has the right timing pulled ] any sooner than the guys with bigger injectors .
Old May 19, 2008 | 05:13 PM
JCstart's Avatar
JCstart
+1 and any blown engine due to a vortech here ?
Old May 19, 2008 | 06:19 PM
str8dum1's Avatar
str8dum1
ya there's been at least 3 people.
Old May 19, 2008 | 06:25 PM
booger's Avatar
booger
I blew my motor , but not from being lean because I ran out of injector . Most that blow are from not enough timing being pulled
Old May 19, 2008 | 06:30 PM
Hexxum001's Avatar
Hexxum001
Go for it man. Good luck to you.
Old May 20, 2008 | 02:29 AM
Bahraini350Z's Avatar
Bahraini350Z
well... I don't wanna sound like a wise guy here. But this was my case. In fact, i had 2 widebands fitted on my car the day i dynoed it. With the 2.87 pulley and 10.5 psi the car was too rich as I explained earlier. I was surprised to see that, was already planning to get a better fuel system as I always follow the useful tips of members like "Booger" and "Sentry".
That is why I had my car dynoed before tracking it, so basically, it had the 3.12 tune on it when I dynoed it with the 2.87! So, 395whp untuned and too rich.
I tracked the car since then 3 times (after doing some correction to the mid range AFR) and even managed to get 1st on A2. (check linky)
http://forums.crcbahrain.com/showthread.php?tid=351
http://forums.crcbahrain.com/showthread.php?tid=344
The question is, did any one run lean on this pulley and was really needing the bigger injectors and fuel pump? or it is just an anticipation?
p.s. I did not order bigger injectors coz my friend was running stock injectors on his SC350Z with similar boost (if not more:s) and was running rich too!
Old May 20, 2008 | 03:51 AM
JCstart's Avatar
JCstart
did you play with your timming ?
Old May 20, 2008 | 05:22 AM
Bahraini350Z
no.... could that be why?
Old May 20, 2008 | 07:37 AM
Nexx's Avatar
Nexx
me, look at my sig.
Old May 20, 2008 | 09:06 AM
JCstart's Avatar
JCstart
Originally Posted by Nexx
me, look at my sig.
you did that with a Vortech ? what was your setup ?
Old May 20, 2008 | 09:25 AM
fishclub's Avatar
fishclub
Good luck with you motor I max out my 440cc at 5500rpm with the 3.12 setup! I am switching to 650cc right now
Old May 20, 2008 | 10:15 AM
Nexx's Avatar
Nexx
2.87 pulley, 550cc injectors, walbro 255lhp, crappy tune.
Old May 20, 2008 | 01:25 PM
  #38
Bahraini350Z
do u have the revup engine?
Calinismo350z
Sep 14, 2015 04:04 PM
esemes
Jul 22, 2004 02:51 PM
Shift_Speed
Aug 16, 2003 05:57 PM
nwind21
Apr 28, 2003 02:14 PM
