Brian Crower Stage 3's Preliminary test results are in!
Old May 30, 2008 | 06:01 PM
  #101
turismo's Avatar
turismo
Whats done to the motor? Is this a stroker or stock sleeving?
Old May 30, 2008 | 06:11 PM
  #102
IIQuickSilverII's Avatar
IIQuickSilverII
stock crank i believe, sleeved? yes
Old May 30, 2008 | 08:14 PM
  #103
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by Julian@MRC
Just to confirm...
Are the red lines in this graph the previous posted intitial run on the Stage 3 cams, or is that the old Stage 2 cam results?
Old May 30, 2008 | 08:33 PM
  #104
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Also...
^ Is this graph the 14PSI comparison between the Stage 2 and Stage 3 cams that we were waiting for? It wasn't clear in your post, although the boost levels appeared to be pretty close in the second graph of your post.
If not, are you planning on doing a direct comparison at the same boost level?
Old May 31, 2008 | 04:05 AM
  #105
Julian@MRC's Avatar
Julian@MRC
Stock sleeved 3.5 liter motor.
Originally Posted by RudeG_v2.0
Also...
Correct Stage 2 to stage 3 different PSI levels. Stage2@15 psi and the Stage3@18.5 psi.
Just to confirm...
Stage 3 to 2 same psi levels
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
