In The Works...
Old May 19, 2008 | 11:09 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
Originally Posted by Alberto
Wow-very cool. Def unique!
Thanks man! Like I said, it wont be the biggest or the baddest but it will be unique and I think it will be perfect for what I want to achieve.
Pics and full write-up are a long way off. Sam wanted till the end of June (about 6 weeks). Even though it's going to be tough to wait that long I am totally fine with it. I don't want him to rush at all. It's similar to when Im operating.....it's not about how fast it gets done, it's all about the end result.
Old May 19, 2008 | 11:30 AM
jonnylaw's Avatar
jonnylaw
Originally Posted by DRIFT
agreed....what's the status on your car. Weren't you waiting for a special harness or did it come in?
It was great to have the prelim info on the first couple of cars that Sam did before I pulled the trigger on mine. Im so glad the HKS SC came out when it did.
I have a revup, and the HKS SC for the revups are a special order item from HKS Japan (approx. 6-8 week wait). Also, since I have a G coupe, Sam agreed to make a supplemental kit so it will bolt on to my g35 (approx. 2-4 week to make the suppl. kit). I believe the kit was ordered early April, so hopefully it will make it's way to GTM shortly.
Besides existing bolt-ons, I plan to upgrade to the vpro, smaller GTM pulley, AFK, and possible fuel upgrade. Goal is a reliable ~375 whp dynojet, on 93 octane.
Sound like u'll have a great and unique setup! Is everything going to be done at once (s/c install and engine build)?
Old May 19, 2008 | 11:35 AM
saberphx's Avatar
saberphx
What kind of exhaust are you going to run? I'd like to hear this thing.
Old May 19, 2008 | 11:38 AM
SpoilsofWar's Avatar
SpoilsofWar
What sort of compression is this stroker going to be running?
Old May 19, 2008 | 11:48 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
93 octane.....not here, Cali fail.
Sounds like we will be up and running around the same time or you may get finished sooner. The time for my project is dependent on the engine build. Everything else should only take about a week.
Yep, SC and Stroker all at once. It's actually less expensive in the long way to pony up for it all now. Im out of money after that so Ill have to come back for gauges, engine bay dress-up, Cosworth (or other) plenum, etc. I'm running the Nismo exhaust and Sam is going to try to make it all work with that but it may have to get switched out.
I will also have to get better rubber which will hopefully happen at the very end of the build. Currently running T1R's on Volk SF Challenge. Im going to change out to Enkei RPF1 in SBC finish with Toyo R888's ..... sizing and fitment as per Sam.
Old May 19, 2008 | 11:49 AM
DRIFT's Avatar
DRIFT
All LASER LASIK
Keeping my Nismo for now to help control cost but may have to go with an HKS.
Old May 19, 2008 | 12:36 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
Hey, you're that mean guy from post #4 that didn't appreciate the teaser.
As far as compression, dont hold me to this but as I recall Sam was going to go around 10:1 to "let the engine do most of the work" and add the boost from the HKS SC as "icing" ... those were his words. I could be off on the number but will clarify it for you when I find out.
Old May 19, 2008 | 12:37 PM
davids's Avatar
davids
F U StuLax18
In for pics.
Old May 19, 2008 | 12:42 PM
SpoilsofWar
Lol, dont be sad... Its just that in the FI section, teaser threads = fail...
As far as the 10:1, right on. Thats how I would do it. If I could do my build over I would not have lowered the compression as low as I did using the Arias 8.6:1's.
Old May 19, 2008 | 01:37 PM
SlideFox's Avatar
SlideFox
Wow that's low! I usually suggest to people 9.0:1 or 9.5:1 compression.
Old May 19, 2008 | 02:35 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Post results after it is done...............good luck.
Old May 19, 2008 | 02:45 PM
Lawy'dU's Avatar
Lawy'dU
Very close....great guess!
It's going to be a 4.0L stroker with modified HKS Supercharger. The engine is going to be fully built with Stage 3 head work and GTM cam. Going with the F-Con V PRO. Staying with 600 cc injectors for smog reasons.
We went with the 4.0L instead of the 4.2 because it isnt that much less displacement and he wont have to sleeve it. It's primarily a street car/DD with occasional track and AC use. He has never done this set-up and Im psyched to see how it turns out. I know there are guys out there that are bigger and badder (I saw George's orange monster on the rack ) but this is going to be my own little California approved monster.
why? It's still going to produce very little power. You should have gone TT and not taken GTM's advice on the HKS Supercharger. Damn these fools are hawking those like crazy.
Old May 19, 2008 | 02:47 PM
jonnylaw's Avatar
jonnylaw
^^stop trolling hater. We all know u r a RA and JWT nuthugger. Calling one of the most respected and talented shops "fools" isn't helping ur cause either.
Face it bro, these kits sell themselves, they don't need someone to "hawk" them.
Maybe ur having buyers remorse, maybe u r a hater by nature. Either way u r starting to get annoying saying the same bs over and over again.
U don't see me chitting on ur vortech threads talking bout bad bearings and shady RA business practices do u?
Old May 19, 2008 | 03:05 PM
mistico's Avatar
mistico
Sounds great man.
I thought the HKS wasn't CARB approved yet, did this happen already, or is it only the revup kit that isn't approved yet?
Old May 19, 2008 | 04:48 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
Originally Posted by mistico
Sounds great man.
Thanks! HKS SC is CARB since early this year at least for the non-RevUp which is what I have. I dont know about the RevUp but jonnylaw can give you more info.....see post #22.
Old May 19, 2008 | 04:52 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
Oh for sure! Ill put up whatever I know but the real info will come from Sam. Im sure he will do a nice write-up with pics and dynos.
Old May 19, 2008 | 05:25 PM
jonnylaw's Avatar
jonnylaw
Yea, the non-revup complete kits for the Z/G/FX are carb approved (using the 2 aux fuel injectors and ~6 lb pulley).
The revup kits are not carb approved, and from what I've heard HKSUSA has no eta on getting the revup kit carb approved, and will likely remain a special order item from Japan.
Getting carb exemption is a lentghly process that requires lots of time, effort, and money. Having said that, it is possible for carb exemption down the road, especially if HKSUSA gets some help for it if they is a high demand enough imo.
Also, how HKSUSA deals with EO's is that it is not stamped on the blower itself, but a certificate issued to the owner that has the EO on it and it registers back to the SN on the blower.
Old May 20, 2008 | 08:51 AM
  #38
c3 rolling's Avatar
c3 rolling
Who owns the HKS S/C'd G35 at GTM? Man I was staring at the HKS kit and it definitely is some high quality stuff, makes my Vortech and Prochargers look like a DIY handmade garage job lol. Interesting how these units make so much power with a tiny blower.
To the OP, congrats and I hope you are happy with the end results.
Old May 20, 2008 | 08:58 AM
  #39
NickRaine78's Avatar
NickRaine78
sub-ing
Old May 20, 2008 | 07:41 PM
  #40
iknowitsfast's Avatar
iknowitsfast
i cant wait to see the results of this monster
