Yay Meth kit installed on my own :D LARGE PICS
Old May 20, 2008 | 09:32 PM
  #41
c3 rolling's Avatar
c3 rolling
Originally Posted by carfi179
Selling it because wifey suggested to just keep 1 toy or else... when are you picking your car from the GTM? are you planning to use the boost juice from them?
Im picking it up on friday morning. Im using the coolingmist brand pre mix. Its liked 50 bucks shipped for 4 gallons. After these are done Im going to just mix my own ****
Old May 21, 2008 | 11:37 AM
  #42
str8dum1's Avatar
str8dum1
i wouldnt bother getting a retune until you are using the stuff that you will constantly use. esp if you are mixing windshield fluid.
i just order mine here in 20L jugs.
http://www.sigmaaldrich.com/catalog/...il/SIAL/179957
Old May 21, 2008 | 10:46 PM
  #43
c3 rolling's Avatar
c3 rolling
Originally Posted by athenG
Windshield washer temp is based on weather condition. Since SoCa hardly see temp below freezing this is why it will be hard to find washer below -20F. Look around coz I'm pretty sure you'll find -20F windshield washer or just mix your own or just look for shop that already sell pre-mixed. Company also change their mix depend on the season so during the summer the tend to cut down on the -36F. In NYC the lowest I can find is -36F but can Canadians can get -50F
Edit:
You (CA) guys get screwed with gas octane, CARB and now Windshield Washer Fluid
I was at walmart and I could find was +36 farenheit/-0 celcius windshield wiper fluid. According to Peaks website....its 1% methanol...lmao.
I bought 30 bucks worth of HEET which will make 4 gallons of 50/50 mix. Still a better deal then Boost juice, saving about 20 bucks but I wish I can find some better windshield wiper fluid. I wouldnt mind the Peak -20 farenheit fluid because its rated at 35% methanol..
Old May 22, 2008 | 06:10 AM
  #44
athenG's Avatar
athenG
/\ Windshield washer fluid do their mix by volume and not weight so technically it is much less than that. I'm currently doing my own mix of 40% Meth and 60% water and I see that my A/F drop about .2 compared to a -36F windshield washer which is supposed to have 40% meth..
How much did you pay for the Heet? Try to find a VP dealer in your area and just pickup a 5 gallon Meth.
Old May 22, 2008 | 06:46 AM
  #45
str8dum1's Avatar
str8dum1
.2 drop? too bad you cant measure IAT. wonder how much a little change in AF (which is related to the volume of meth sprayed --daily temp swings alter my AF that much) can cool the IATs.
Old May 22, 2008 | 09:33 AM
  #46
jpc350z's Avatar
jpc350z
Could you not log IAT with UTEC?
Old May 22, 2008 | 09:42 AM
  #47
athenG's Avatar
athenG
You can, but not the IAT after Meth coz you have to spray after the MAF....
Old May 22, 2008 | 09:47 AM
  #48
05Z33's Avatar
05Z33
Are you guys getting better fuel mileage with these water meth kits under normal driving conditions? I ask this cause I found this product called a hydro4000, which is basically setup the same way as a water meth kit, and they are getting better mileage.
Old May 22, 2008 | 09:58 AM
  #49
c3 rolling's Avatar
c3 rolling
Ahh ic. Heet was 1.20 per 12 ounce bottle at Walmart and I bought about 22 . When I mix this 50/50 with water, Its bascially 12 ounce meth to 12 ounce distilled water correct? Whats this weight you speak of? If I just buy a gallon of -36 wiper fluid and throw in two bottles of heet, wouldnt that be a very high meth content? +50 %? Yea Ill try looking for a VP dealer, for now I think I have about 2 months supply in my garage
Old May 22, 2008 | 10:29 AM
  #50
athenG's Avatar
athenG
Meth and water has a different weight. Meth weigh 6.6 pounds per gallon and Water weigh 8.34 pounds per gallon.
if you're looking to make 1 gallon of mix, you need .44 gallons water and .56 gallons meth (1.67 L water and 2.12 L methanol). If you do a 50/50 mix using volume then you are pretty much in the ball park of 40% meth and 60% water. It is the consistency of the mix that is more important so make sure the percentage is always constant.
Old May 22, 2008 | 10:34 AM
  #51
c3 rolling's Avatar
c3 rolling
ahhh thanks alot man for all the great info . I just found a shop that sells pure meth in 5 gallon drums for 40 bucks in the area! Now it puts my mind at ease that I wont be constantly hunting for meth and the price wont dent my pocket
Old May 22, 2008 | 11:08 AM
  #52
athenG's Avatar
athenG
$40 is a good price. You can make 10 Gallon mix of 40/60 (Meth/Water) with that. All you have to do is buy some distilled water for .99C.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Juztin
Nov 22, 2015 07:03 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
