Gap!?
Old May 24, 2008 | 11:17 PM
aguita's Avatar
aguita
Default Gap!?
Changing plugs I searched and didnt find anything..
What gap should i set the plugs ???
thanks
Using Iridium ones
Old May 24, 2008 | 11:31 PM
wannabuy350z's Avatar
wannabuy350z
whats your boost level(PSI)? any nos? meth? stock compression
Old May 25, 2008 | 03:12 AM
westpak's Avatar
westpak
SFZCC
i keep them the way they come you risk damaging the tip
i know the 2 step colder come gapped at 0.032
Old May 25, 2008 | 04:00 AM
superchargedg's Avatar
superchargedg
Damn Noobs
+1 and if you try and gap them you will more then likely damage the electrode.
Old May 25, 2008 | 11:22 AM
aguita's Avatar
aguita
Stock Compression,Stock Vortech Boost
Do the plug come with any gap?
Old May 25, 2008 | 07:25 PM
wannabuy350z
standard is .44 gap, so average voretch is like 9 psi. I would gap it .35, stock gap isnt bad also. run copper plugs for that boost level. heat range level 6 NGK
Old May 25, 2008 | 10:08 PM
aguita's Avatar
aguita
thanks for the response..after searching harder i found a post from early 2007 that pretty much says that..
Stock Gap is a .44 so that is the -11 on the plug numbers which isnt pretty bad
Yep im gettin cooper...
thanks again
Any other Inputs?
Old May 25, 2008 | 11:10 PM
wannabuy350z
torque them down correctly, if your doing it yourself.
Old May 26, 2008 | 05:24 AM
Jay'Z's Avatar
Jay'Z
torque is 22 ft pds or inch pds? I forget...
Old May 26, 2008 | 06:54 AM
03VQ35DETT's Avatar
03VQ35DETT
so are the copper plugs really worth the frequency that you have to change them, im just wondering cause i've never really looked into them much i've just always stuck with iridium
Old May 26, 2008 | 02:14 PM
wannabuy350z
economically its a good choice. change plugs with oil change.
kgb
Sep 15, 2018 05:29 AM
35reilly
Sep 28, 2015 07:42 AM
AP350z223
Sep 8, 2015 04:38 PM
s9am_me
Oct 15, 2003 04:01 AM
