fuel door not lined up??
Old Oct 14, 2003 | 03:27 PM
s9am_me's Avatar
s9am_me
Default fuel door not lined up??
gap seems to be a bit too much. not really a big problem for me... just wondering if anybody else's Z is like this. or is this how its suppose to be??
s9am_me's Avatar
s9am_me
here's a more wider shot....
Old Oct 14, 2003 | 03:28 PM
havabooz's Avatar
havabooz
not how its supposed to be..i took mine off once...you just gotta loosen and adjust and then keep tryin it out
Old Oct 14, 2003 | 03:30 PM
s9am_me's Avatar
s9am_me
hmmmm... arite... i'll try that
Old Oct 14, 2003 | 03:55 PM
del105's Avatar
del105
15 f125
is your car chrome.
Old Oct 14, 2003 | 04:07 PM
s9am_me's Avatar
s9am_me
Originally posted by del105
is your car chrome.
Super Black.
Old Oct 14, 2003 | 04:23 PM
SweatyPalm's Avatar
SweatyPalm
Originally posted by s9am_me
Super Black.
How many layers of Zaino did you apply? That looks awesome.
I'm also having some problem with my fuel door but it's not about the gap. I had to push the door button a few times to open the fuel door.
Old Oct 14, 2003 | 04:50 PM
del105's Avatar
del105
15 f125
I had the same problem just slowly bent it to fit with my hands.
Old Oct 14, 2003 | 05:07 PM
ZpikeZ's Avatar
ZpikeZ
I just noticed that on my SB a few weeks ago ... oh well, we're just gonna have to live with it. I'm not gonna try to bend it into shape cause i'll probably break it.
Old Oct 14, 2003 | 06:14 PM
mgl's Avatar
mgl
mines also not aligned very well, but not as bad as yours. let me know if you can successfully fix it.
Old Oct 14, 2003 | 06:21 PM
Dissolved's Avatar
Dissolved
mine is really misaligned as well. Thought it was just me. phew
Old Oct 14, 2003 | 06:32 PM
Zsilverstone13's Avatar
Zsilverstone13
Mine is not aligned totally, but not as bad as the picture shows. Check if the line that connect to the gas cap does not stick between the gas door and the body.
Old Oct 14, 2003 | 07:39 PM
samw1978's Avatar
samw1978
Mine's the same, but not as bad
Old Oct 14, 2003 | 07:40 PM
havabooz's Avatar
havabooz
this just happens from the constant opening and closing of the door....the way the bolts are set up it loosens every time it is opened...so the longer you have your z...the worse it should be
but its a simple fix
Old Oct 14, 2003 | 07:52 PM
Montez's Avatar
Montez
Mine was like that to, I did bend it a little so its a little better now.
Old Oct 14, 2003 | 10:14 PM
s9am_me's Avatar
s9am_me
No Zaino for me... I only use Blackfire (see sig)
thanks for the replies.. just glad i'm not the only one
Old Oct 15, 2003 | 04:01 AM
03ZUC's Avatar
03ZUC
I think everyone has had this problem. The problem is the plastic line that holds the cap. Rotate it around to the right side of the cap after its twisted on and close the door. This works everytime for me.
