Detonation....Knocks and pings sigh
Old Jun 11, 2008 | 09:56 AM
  #61
athenG's Avatar
athenG
Originally Posted by c3 rolling
not too sure. The knock is so elusive that I cant really tell. Seems WOT on first gear will trigger the knocking near redline. Once the meth/water starts to really work it would stop. If I WOT from a 40 mph cruise it wouldnt knock, possibly the pre mix had enough time to really cool things down and work..
So why not just tone down the tune up top? Adding more meth will just create more problem. The quickest way to find out is just remove a couple of degree of timing up top (knock area) and see if the knock goes away. Adding more meth will put your entire tune out of balance.
Old Jun 11, 2008 | 10:07 AM
  #62
jpc350z's Avatar
jpc350z
Have you ruled out a bad knock sensor? Would the ECU through a code if it was bad or even marginal in performance? Having this problem with the Stillen and now Vortech suggests a system problem.
Old Jun 11, 2008 | 11:06 AM
  #63
ESP350Z's Avatar
ESP350Z
IMHO meth seems more like a bandaid at this point. Didn't you have a stillen S/C before? Did your car have detonation then?
Old Jun 12, 2008 | 08:30 AM
  #64
c3 rolling's Avatar
c3 rolling
I have audible knock at high rpms
  #65
c3 rolling's Avatar
c3 rolling
Yes it did, only on stage 3 though. Never heard knock on stage 2
Old Jun 12, 2008 | 08:45 AM
  #66
gothchick's Avatar
gothchick
If you can actually hear knock above road noise and exhaust... Then it's pretty bad knock... I'd back the tune off a bit and look for any mechanical problems before adding more meth. Otherwise you're going to have a pile of broken parts on your hands.
Old Jun 12, 2008 | 10:01 AM
  #67
c3 rolling's Avatar
c3 rolling
timing has already been reduced in high rpms about a week ago. Even though its possibly okay now, the fact that my car is knocking too easily is still an issue. What mechanically can cause this knock? plugs, leaks, injectors, have been checked
Old Jun 12, 2008 | 10:10 AM
  #68
jpc350z's Avatar
jpc350z
From a quick google search,
The most common symptom of excessive oil clearances is an awful knock coming from the engine. Low oil pressure is also a symptom of excessive oil clearances but is less common (by the time the oil pressure goes low there's usually an engine knock evident). Engine knock can be caused by worn rod bearings, main bearings, piston pins, pistons, and cam bearings. Sometimes some types of engine knock can be repaired with the engine in the car. The engine must be partially disassembled to know for sure.
Old Jun 12, 2008 | 10:14 AM
  #69
c3 rolling's Avatar
c3 rolling
damn, how the fark can my engine components be worn if I bought the car new a year ago and it only has 25k miles on it. Most of it was N/A with conservative highway miles. Never tracked or abused
Old Jun 13, 2008 | 10:15 AM
  #70
c3 rolling's Avatar
c3 rolling
dont know if this is relevant but when I was N/A i was getting 21 mpg but now with the vortech im getting 27 mpg. Granted my commute has changed a bit but the difference seems really large
Old Jun 13, 2008 | 10:32 AM
  #71
redzzand's Avatar
redzzand
you should do an oil analysis... blackstone-labs.com
this will tell you if its your bearings or not...
Strife350z
Jan 22, 2004 10:41 AM
SpoonieLuv
Nov 22, 2003 02:28 AM
MastaKillaZ
Southern California
30
Aug 20, 2003 08:20 PM
