can timing cause overheating??
Old Jun 12, 2008 | 09:44 PM
clemlover15's Avatar
clemlover15
Default can timing cause overheating??
hey,
if idle timing was set way to much could that cause overheating??
Old Jun 13, 2008 | 06:10 PM
nomyth46's Avatar
nomyth46
not likely..................i'm tellin ya............i don't do any performance stuff at my shop but i have seen hundreds of cars come through with the exact same problem you are having to a T..........its you rad. fans
Old Jun 13, 2008 | 07:19 PM
JCstart's Avatar
JCstart
Originally Posted by clemlover15
hey,
the good answer is YES...
Old Jun 13, 2008 | 07:28 PM
surfcity40's Avatar
surfcity40
overheating is caused by the the cooling mechanisms being unable to cool the resulting heat from what you are doing to the motor to get more hp. That is the simple answer. It is unlikely that retarding or increasing the timing alone could cause an overheating issue to that degree. Your motor would be running pretty oddly.
I'm guessing you need a cooling service.
Old Jun 13, 2008 | 07:33 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The short answer, is that you are unlikely to change the operate temp of an engine at idle in a meaningul way...by adjusting timing at idle.
Go back to your original thread...the suggestions and answers are still there. Best of luck....call if you need anything.
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
