Stock flywheel and pressure plate bolts, Halp!
Old Jun 12, 2008 | 07:01 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Default Stock flywheel and pressure plate bolts, Halp!
I had a problem with my triple carbon clutch and in order to diagnose the problem I needed to put my stock clutch back in for about 5 minutes to troubleshoot my problem.
the only thing is I threw away all my PP and flywheel bolts!
does anyone have any used stock flywheel and PP bolts that they didnt throw away? I dont want to buy new ones if I am only going to use them for 5 minutes. Thanks.
Old Jun 12, 2008 | 08:26 AM
thawk408's Avatar
thawk408
They are probably not that exp from nissan.
Old Jun 12, 2008 | 08:33 AM
SlideFox's Avatar
SlideFox
I would just go to your local Nissan Dealership and hit up the parts department.
Old Jun 12, 2008 | 08:37 AM
thawk408's Avatar
thawk408
I know a headbolt is only $3 bucks, and those are way bigger then the bolts you need.
Old Jun 12, 2008 | 08:54 AM
Blackbird CPV35
flywheel bolts are 4.79 a piece and PP bolts and washers are pretty hefty too, not to mention they are on backorder. The total price shipped would come out to be $80, which i think is crazy since I will only be using them for about 5 minutes or so. I was hoping someone would be kind enough to give me some used ones that they were going to throw away anyways instead of dropping $80.
Old Jun 12, 2008 | 09:32 AM
SpoilsofWar's Avatar
SpoilsofWar
I think I have the pressure plate bolts in a ziploc from build, somewhere. I will see if I can find them for you. Can't help with the flywheel bolts as I reused my stock flywheel.
How many PP bolts should there be? So if I do find them I will know if they're all there... I can't remember off hand.
Old Jun 12, 2008 | 10:51 AM
Blackbird CPV35
i beleive there are 9 pp washers and bolts and there are 8 flywheel bolts. i would appreciate any help, this build has been really physically mentally andeconomically draining and i really want to get it on the road
thanks
Old Jun 12, 2008 | 11:43 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
thanks
Welcome to the built motor with TT club!
Old Jun 12, 2008 | 03:26 PM
Blackbird CPV35
Old Jun 12, 2008 | 03:32 PM
SC 350Z's Avatar
SC 350Z
^ hey man if you know the thread size and count go to lowes you can get metric which i would beleive they are i wouldnt use them to run your car becasue they are not hardend bolts but would work fine for what you need and you would spend 10 15 bucks
Old Jun 12, 2008 | 03:41 PM
Blackbird CPV35
i think Sharif may have some PP bolts, i will wait to see if anyone has any flywheel bolts then i guess thats my last option
Old Jun 13, 2008 | 08:27 PM
SpoilsofWar
I'm sorry bro, I absolutely tore apart my storage room trying to find those bolts for you, to no avail. I guess maybe I tossed them when I moved last week... Sorry dude
Old Jun 14, 2008 | 04:15 AM
Blackbird CPV35
dont worry guys, Sharif saved my *** again
EnjukuRacing
Sep 30, 2015 06:55 AM
