Top Speed Limiter Removal
Old Jun 17, 2008 | 07:37 PM
JETPILOT's Avatar
JETPILOT
Default Top Speed Limiter Removal
I need to have the top speed limiter removed from the ECU. I know Technosquare can do it but they wan't $500. Can I get it done anywhere else cheaper?
Old Jun 17, 2008 | 07:46 PM
blueper4mancez's Avatar
blueper4mancez
i thought the L spec flashed the technosquare for 350 ? that's how much i was told .
Old Jun 17, 2008 | 07:48 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I have a rev-up ecu with the mack daddy GTM reflash that I will trade for your stocker plus 500.
Old Jun 17, 2008 | 07:52 PM
JAM3Z's Avatar
JAM3Z
Phenom
The GTM reflash is pretty good. How fast are you looking to go JET?
Old Jun 17, 2008 | 07:53 PM
doug's Avatar
doug
i thought the F-Con does this also
Old Jun 17, 2008 | 07:54 PM
JAM3Z's Avatar
JAM3Z
Phenom
There are certain things the FCON can't do, and I believe this be one of them.
Old Jun 17, 2008 | 08:03 PM
XKR's Avatar
XKR
I agree...the GTM reflash is nice....
If I am not mistaken...I was told to remove the speed-limiter you have to do it in the stock ECU.
Old Jun 17, 2008 | 08:05 PM
JAM3Z's Avatar
JAM3Z
Phenom
I wonder if this would help
http://www.hksusa.com/categories/?id=1926
Old Jun 17, 2008 | 08:14 PM
JETPILOT's Avatar
JETPILOT
On the back straight comming into turn 17 @ Sebring I always hit the speed limiter and there is another 1/5 mile or so to accelerate. So I want it removed. Sorry Louie... I don't have a rev-up.
GTM eh? Wonder what that costs.
EDIT: Just found out the GTM reflash costs $600. I'm not willing to pay that for a speed limiter removal.
Old Jun 17, 2008 | 08:20 PM
JETPILOT's Avatar
JETPILOT
L Spec? What is L Spec?
Old Jun 17, 2008 | 08:21 PM
jonnylaw's Avatar
jonnylaw
L-Spec Technosquare would be cheapest solution (thought price dropped to ~$250, but coud be wrong, might be more), but downtime for having to ship out your ecu to them and back.
Old Jun 17, 2008 | 08:23 PM
jonnylaw's Avatar
jonnylaw
L-spec (guessing stands for "limited" spec), not F-spec ("full spec").
F-spec is their full reflash: target A/F, ignition timing, speed limiter removal, throttle control
L-spec just removes speed limiting, and makes changes to electronic throttle control stuff I think.
http://www.technosquareinc.com/nissanflash.htm
Old Jun 17, 2008 | 08:44 PM
JETPILOT's Avatar
JETPILOT
Ahhh.... Thanks for clearing that up. The car is not a daily driver so downtime is no big deal.
Old Jun 17, 2008 | 11:13 PM
mcarther101's Avatar
mcarther101
NM.... thought this could remove speed limiter, but it can't:
https://my350z.com/forum/engine/345590-cobb-accessport-now-available.html
Old Jun 18, 2008 | 07:45 AM
Hoooper's Avatar
Hoooper
usually the l-spec gives you extended revs too
Old Jun 18, 2008 | 08:59 AM
rcdash's Avatar
rcdash
If you're considering the reflash, I would suggest Osiris, which includes Cipher for diagnostics, and allows multiple reflashes/maps - all for $700. Soon an end user tuneable version of the software will be released as well...
Old Jun 18, 2008 | 09:01 AM
iStan's Avatar
iStan
ZR
$300
at UpRev
Speed Limiter, Rev Limiter, Throttle Control, Idle.
Old Jun 18, 2008 | 01:44 PM
r0mey's Avatar
r0mey
GTM reflash I think is the best bet. Like anything you pay for quality. So as you know you go to pay to play. And there is much more in the reflash because the speed limit
Old Jun 18, 2008 | 02:32 PM
Hoooper's Avatar
Hoooper
jetpilot arent you boosted with an greaddy TT? if he is like i thought he was then the GTM and all the other tunes arent really good since im sure its already tuned and he just wants the limiter removal. i would call forged and ask them about it, they might be able to give you a deal since they do the TS ecu in house and you can maybe get just the limiter removed for cheap if you let em know the situation
Old Jun 18, 2008 | 03:17 PM
JAM3Z's Avatar
JAM3Z
Phenom
wat?
