PCV has Hole In It
Old Jul 1, 2008 | 01:34 AM
JETPILOT's Avatar
JETPILOT
Default PCV has Hole In It
I was doing a pressure test on a PCV valve and found that the PCV valve has a small pinhole through the center that does not allow it to seal. Check it out for yourselves. Interesting!
I remember someone mentioning a one way check valve... anybody put one in?
Old Jul 1, 2008 | 04:18 AM
QuadCam's Avatar
QuadCam
pressure testign your PCV at 5:30AM.....get some sleep man!!!!
Old Jul 1, 2008 | 05:22 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yeah thats why a lot of cars smoke on decel cause of that damn thing...
Old Jul 1, 2008 | 05:27 AM
JAM3Z's Avatar
JAM3Z
Phenom
For the less technically savvy amongst us, what exactly is a PCV valve?
Jay'Z's Avatar
Jay'Z
Old Jul 1, 2008 | 05:41 AM
coachk's Avatar
coachk
Its a valve that helps get the gases out of the crankcase
Old Jul 1, 2008 | 06:22 AM
rcdash's Avatar
rcdash
I run a second check valve to prevent boost from getting into the crankcase. I use the following setup:
PCV --- catch can ---- T ---- check valve ---- intake manifold
The other end of the T ---- check valve ---- turbo intake
The check valves both allow air only away from the catch can.
The driver's side vent is open to free air with a breather and it has not gotten oily or dirty these past few weeks I've been running, so I'm assuming it is only sucking air in, as it should be.
Old Jul 1, 2008 | 06:55 AM
Barzten1's Avatar
Barzten1
Any pics Jet?
Old Jul 1, 2008 | 08:05 AM
SpoilsofWar's Avatar
SpoilsofWar
rcdash, what is the purpose of using the T and running to both the intake manifold and pre turbo?
I think I will run a check valve in mine as well, just to be safe. And I am definitely going to just vent the driver's side, because I am sick of that huge 5/8ths hose getting crimped running all the way to the intake piping up front.
Old Jul 1, 2008 | 08:25 AM
frankie945's Avatar
frankie945
My pcv valve was cracked I never heard it with my procharger on except my idle would go up and down.When I installed a TN kit I heard it hissing. Replaced the valve and hose now my idle is perfect and no more hissing nose.
Old Jul 1, 2008 | 09:24 AM
QuadCam's Avatar
QuadCam
Positive Crankcase Ventilation
Old Jul 1, 2008 | 09:55 AM
JETPILOT's Avatar
JETPILOT
Check valve info please? Where can we get these?
Car work before sleep!
Old Jul 1, 2008 | 11:25 AM
rcdash's Avatar
rcdash
The idea is to have crankcase ventilation all the time. If you stay in boost for an extended period of time, vapors will be trapped in the crankcase and have to flow out the driver's side breather, spewing oil vapors into the engine bay. You therefore need to find a vacuum source that exists during boost. The only two that I can think of are in the pre-turbo intake piping (just after the air filter), or in the exhaust. Hence the T and the two check valves.
I had mine installed at Forged prior to pick up. Sharif probably has a source...
Old Jul 1, 2008 | 12:33 PM
SpoilsofWar
Interesting. I may set mine up similarly, because I will have that preturbo intake pipe nipple open when I switch the drivers side to a breather filter. That way I wont have to bother sealing it off.
IIRC APS makes some check valves for this purpose. But I could have them confused with someone else.
Old Jul 1, 2008 | 06:30 PM
Weqster's Avatar
Weqster
The APS kit includs check valves for the PVC
Old Jul 1, 2008 | 06:47 PM
SlideFox's Avatar
SlideFox
Originally Posted by Weqster
The APS kit includs check valves for the PCV
Fixed
Old Jul 1, 2008 | 06:51 PM
JETPILOT's Avatar
JETPILOT
Anyone know where we can order these APS valves. I don't want to have to steal someones at the next meet.
Old Jul 1, 2008 | 06:53 PM
SlideFox's Avatar
SlideFox
Originally Posted by JETPILOT
Anyone know where we can order these APS valves. I don't wantto have to steal someones at the next meet.
Contact an APS Dealer? I would think an authorized dealer would have access to spare parts!
Old Jul 1, 2008 | 06:55 PM
JETPILOT's Avatar
JETPILOT
Who's an APS dealer on these boards?
Old Jul 1, 2008 | 07:00 PM
SlideFox's Avatar
SlideFox
GTM, Injected, MRC, Z1 Performance
