Help - IS MY MAF BUSTED? or..
Old Jul 20, 2008 | 06:35 PM
NH01's Avatar
NH01
Default Help - IS MY MAF BUSTED? or..
Current mod.. Vortech full kit.. exhaust..bolt on's etc..
anyway..
when i was driving home.. cruising for about 2hrs.. then when as we were exiting on the off ramp, i decided to give the car a little boot, the car just stops going..(as in feels like it cut fuel..)
luckly i have a wideband
when car idles it runs SUPER Rich in the 10's..when driving the car normally it runs ultra rich as well. Until i give more than 20% throttle it starts to get really lean then cuts off again. i guess its the knock sensor protecting me =p
anyway, after this happened i did not get an ENGINE Light.. i just stopped at a gas station right away,unplugged battery, and drove again(b/c i was still about 1.5hours away from home)So the drive home was fine because it was mostly just cruising at constant speed. Until now, i just got home and tried to give it a hard boot again.. boom same thing.. again no engine light..
SOo is my MAF busted?
Will the Engine light come on right away if the MAF is broken?
Thanks
Nick
Old Jul 20, 2008 | 07:56 PM
NH01's Avatar
NH01
I forgot to say.. It was raining really hard for the whole ride..
and it stopped raining now..
I think i should have kept driving it until i got an engine light because it stopped raining now and I cant replicate the problem.
Old Jul 21, 2008 | 05:49 AM
athenG's Avatar
athenG
Check your maf if it is wet, also do you have a Water injection? This happened to me a few times (My Meth kit controller went bad and sprayed even when I wasn't on boost or car is shutdown) and I'm surprised that my MAF is still working. I think your MAF sensor got wet and just let it dry and hope you are ok.
Old Jul 21, 2008 | 06:59 AM
NH01's Avatar
NH01
Yea I think it probably got wet or something.
I couldnt replicate the problem. But i dont see how it got wet though. unless the supercharger is sucking water from my intake duct.
The only thing is, I can unplug battery for a reset then everything works fine again.
Thanks for the info man.
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
