My soon to be 350z in S14 240sx clothing
Old Sep 16, 2008 | 08:28 PM
  #241
pmohr's Avatar
pmohr
Originally Posted by SinisterSntra91
Ohh your right, I stand corrected on the M30. I have seen Maxima owners swap the VQ30DET into their vehicles, this guy also used a FWD maxima VQ30 in his S13: http://www.cardomain.com/ride/767108/2 and I have heard of a guy using a FWD VQ35 in his S13 as well.
I also wanted to put this information out there for those guys who might have blown their current DE or boosted DE and want to put this in their 350z/G35 as a cheaper stock motor that is more suitable for turbo. I have heard that the VQ30 crank and rods are an upgrade for the internals of a VQ35. You could even do a frankenstien version and combine VQ35 heads with VQ30 bottom end. I have searched and there doesnt seem to be much info on this motor on this forum or any other forum or website for that matter.
Well the VQ30DET 'swaps' are really just putting the DET internals in the FWD DE block, because the blocks are cast differently. Short of a custom motor mount and crossmember setup, no way around that.
Rob Tilley did a VQ32 (or 33, I forget which) a while back, but IIRC he didn't run it long enough to gauge reliability and cost effectiveness. Honestly it's easier and cheaper to just use the VQ35 as-is than to hybrid a VQ30 and VQ35 together. There's a bunch of information about most of the hybrid combinations over on maxima.org, just takes a bit of searching.
Old Sep 17, 2008 | 03:48 AM
  #242
SinisterSntra91's Avatar
SinisterSntra91
Interesting, thanks for the info.
Old Sep 17, 2008 | 09:17 AM
  #243
SIN3's Avatar
SIN3
you bring a whole new meaning to wrenching it.... nice work so far.
Old Sep 17, 2008 | 12:12 PM
  #244
KS0385's Avatar
KS0385
F*cking amazing.
Also, I'm a Mechanical Engineer, and have access to a CNC machine along with all the programs needed to design and run parts, so if you need something custom made let me know. Even custom emblems or "badges".
Or if you need Stress Tests/FEA or air flow analysis done, I could probably help with that as well.
Best of luck for the future.
Old Sep 17, 2008 | 04:10 PM
  #245
2004Black350z's Avatar
2004Black350z
Exhaust Whore
ur the **** man. Every where u sit there should be skid marks! subsc for how the turbo build turns out
Old Sep 17, 2008 | 06:58 PM
  #246
Corbic's Avatar
Corbic
So now its off to the shop for some test fitting of the VQ30DET setup on a VQ35DE, this might be a cheaper alternative for those of you looking to go FI (Oh yeah that is metal valve covers you see on that VQ30 instead of those gay plastic ones.....)
Not three months ago I was thinking if the same thing was possible. Keep us updated!
Old Sep 17, 2008 | 07:30 PM
  #247
KhanMan's Avatar
KhanMan
Keep up the good work.
Old Sep 17, 2008 | 09:47 PM
  #248
DracoLancet04Z's Avatar
DracoLancet04Z
unbelievable genius sir omg its going to be a hot machine
Old Sep 19, 2008 | 08:35 PM
  #249
stepuckey's Avatar
stepuckey
ttt
Old Sep 19, 2008 | 08:45 PM
  #250
Spork's Avatar
Spork
Updates!?!?!?!??????
Old Sep 20, 2008 | 03:49 AM
  #251
tranceformer95's Avatar
tranceformer95
Wow, I had no idea there was a VQ30DET.
Great work, OP.
Old Sep 20, 2008 | 03:13 PM
  #252
stepuckey's Avatar
stepuckey
bump
Old Sep 20, 2008 | 05:14 PM
  #253
Z1NONLY's Avatar
Z1NONLY
wow!
Old Sep 23, 2008 | 05:28 PM
  #254
SinisterSntra91
Ok on with some updates. Ameen, Mike and I are working together to come up with a design for a single turbo setup. We came to the conclusion that trying to run such a setup on the car would only be possible if we use the space in front of the motor. We played around with the stock manifolds to find different possibilities. Our first idea was to switch the manifolds, problem was they got in the way of the alternator and the AC compressor. We then tried putting the manifolds back to stock location, then turning them 180 degrees which would have worked great if it werent for the two top corner studs not lining up. So our only option was to cut, flip and tig them back together. So we bought some stainless steel headers:
Cut the flanges off:
Got out the grinder, ground down the old welds:
Let Mike do his thing, which I am still learning how to do:
Some of the welding process:
Did the other side and test fitted:
Now we have to cut the "triangle" type flanges off and put on v-band flanges and start work on a cross pipe to join the two headers the the turbo. Thats all for now.
Old Sep 23, 2008 | 05:30 PM
  #255
Gingervitis526's Avatar
Gingervitis526
keep it up man
Old Sep 23, 2008 | 05:33 PM
  #256
Bolaz's Avatar
Bolaz
You my friend FTMFW!!!!
Old Sep 23, 2008 | 05:36 PM
  #257
benwaballs's Avatar
benwaballs
Old Sep 23, 2008 | 05:44 PM
  #258
wannabuy350z's Avatar
wannabuy350z
awesome, have the turbo sit right in the middle. show it off......
Old Sep 23, 2008 | 05:53 PM
  #259
SinisterSntra91
Fo sho!
Old Sep 23, 2008 | 08:09 PM
  #260
krnzzang84's Avatar
krnzzang84
WOW Good luck, i sure you can pull it off!!
can't wait till the finished product,,,
